List what you've replaced/repaired on your car.
Focus ST 170 Discussion
Re: List what you've replaced/repaired on your car.
Postby *Z3R0* » Thu Jul 07, 2016 8:31 am
So eventually got the rear bumper from Ford, and my baby will be going in for some TLC.
Front brakes were also changed in last month with a service.
Also saw that my right front CV boot was torn, and had that replaced yesterday.
Rear Brake Pads x 2
Front Brake Pads x 3
Clutch/Brake Master Cylinder
Front Bumper
Thermostat
Thermostat Housing
Cambelt
V-Belt
Tappit Cover Gasket
Water Bottle
Gearbox Tourque Link Mount
Changed Engine Mount to Flex 600 Poly/Rubber Mount
Normal Services
All pulleys and tensioners
Aircon Pump Reconned
New Earth cable from Battery to the body
Battery
2 x Front Tyres 215/45/17 Achilles
Left Rear Wishbone/Trailing Arm
2 x Rear Tyres 215/45/17 Achilles
Bosch Wiper Blades
Top Mount Radiator Pipe
Rear Bumper
Front Right CV Boot
2004 Ford Focus ST170 Newskool
1987 Ford Sierra 3.0 GLX Oldskool
1974 VW Beetle Rocking a Roofrack
Make: Chevrolet
Model: Sonic RS
Type: 1.4 Turbo Beasty
Postby Skywalker » Thu Jul 07, 2016 9:32 am
*Z3R0* wrote:So eventually got the rear bumper from Ford, and my baby will be going in for some TLC.
Rear Brake Pads x 2
Front Bumper
Thermostat
Thermostat Housing
Cambelt
V-Belt
Tappit Cover Gasket
Water Bottle
Normal Services
Battery
Bosch Wiper Blades
Rear Bumper
Front Right CV Boot
Hats off to you for putting the effort into keeping you 170 nice and healthy Meneer. It makes ex owners like me happy to know there are still a few of these on our roads =D>
Postby *Z3R0* » Mon Jul 11, 2016 5:59 pm
Shot dude! Will post some pics when she is done 8)
Postby Loupie » Thu Jul 14, 2016 1:03 pm
Loupie wrote:Bought my car June 2009 (108 000km on the clock)
Replaced facume pipe in 2010 (wear and tear)
Brake pads (Normal service)
Clutch, flywheel and cylinders Feb 2011 (**** duur)
:shock:
Thermostat housing
Gear linkage came loose about 2weeks ago, friend fixed it for me :D
Standing on 163 000km
Im one of the lucky ones (Touch wood)
Must admit I nurse my baby.
So Since then I have replaced:
Whole new aircon system and compressor
New Battery
New front bumper (Hit a dog or something, was not cool :( )
Rear discs (New from Fraud, cost me an arm and a leg)
CV Boots
Had the cam belt done on 200 000km
Lamba Sensor (O2 Sensor)
Below all happened because the AC pulley bearing seized
V-Belt
Idle Pulley
Tension Pulley
AC Compressor Clutch, electromagnet and pulley (I did not remove the compressor as it was still working perfectly. The pulley bearing seized and caused everything to get hot and melt.
Running smoothly again and standing on 213 700km
:D :D
One day my ST170 will be the last of it's kind in SA. 8)
Postby *Z3R0* » Fri Jun 23, 2017 7:40 am
So, after roughly 7 years of owning my ST170 she left me by the side of the road for the first time ever, and it was the Powersteeting Pump, had to
replace it and damn, with the labour all in all, was about R8000 to get her going again, but she is fixed and I am happy as chappie again!
Also replaced another 2 x tyres as the previous rear ones worn off on the inside, have to get the rear shimmed and lined up again.
Rear Brake Pads x 2
Front Bumper
Thermostat
Thermostat Housing
Cambelt
V-Belt
Tappit Cover Gasket
Water Bottle
Normal Services
Battery
Bosch Wiper Blades
Rear Bumper
Front Right CV Boot
2 x Front Tyres 215/45/17 Achilles 2233's
Powersteering Pump
Postby *Z3R0* » Mon Sep 18, 2017 3:22 pm
So my drivers side window stopped working and had to pull that out, and found a place that fixes these as Ford was just crazy with their prices.
Had to replace the whole unit, can't buy the plastic guide and the cable apart, so got that fixed and she is sorted.
Wanted to change the fuel pump for years now, as she struggles when driving in the heat and jerks under half indicator on the gauge.
Changed the pump and she is all good to go again, and pulls like a train now.
Very happy!
Rear Brake Pads x 2
Front Bumper
Thermostat
Thermostat Housing
Cambelt
V-Belt
Tappit Cover Gasket
Water Bottle
Normal Services
Battery
Bosch Wiper Blades
Rear Bumper
Front Right CV Boot
Powersteering Pump
Driver Side Window Mechanism
Fuel Pump
Return to Focus ST 170 Discussion
