Karter CAI
Karter Performance Discussion
Moderator: Karter Performance
Model: Fusion
Type: 2.0 TDCI
Karter CAI
Postby piranha786 » Sat Jun 04, 2016 11:27 pm
I have the full Karter CAI in my ST250
Lately when pulling away, I hear this sqeeking noise. I'm not sure whether its just the air that is sucked in that makes the sound, or the airfilter that touch the airbox a bit.
It's kinda annoying. Any1 that has the same experiece?
I'm thinking of putting the stock intake back to try finding the culprit.
Re: Karter CAI
Postby German » Sun Jun 05, 2016 10:22 am
Check the top intake pipe that it isn't touching anywhere.
Otherwise give Karter a call and one of the guys will have a look for you.
Sent from my ONE A2005 using Tapatalk
Model: Fusion
Type: 2.0 TDCI
Re: Karter CAI
Postby piranha786 » Sun Jun 05, 2016 12:14 pm
German wrote:Check the top intake pipe that it isn't touching anywhere.
Top intake pipe is close to thAt small tube, but will see what happen When I take everything off, and replace 1 by 1. Thanks.
Re: Karter CAI
Postby German » Sun Jun 05, 2016 1:16 pm
No idea what small tube you are talking about. It mustn't touch the HPFP but there is usually loads of space between the pipe and the pump. That is the only tube I can think of.
Return to Karter Performance Discussion
