ST225 Drop in Fitment Upgrade Fuel Pumps now available
Devils Parts Discussion
Umlungu
Type: White ST225
Post by Umlungu » Tue Apr 28, 2015 10:14 pm
If you're interested, I have brought in a couple, I will be installing one on my vehicle to document the ease of installation.
Orders -> http://www.devils-parts.co.za/focus-st- ... -pump.html
For all your Performance Accessories visit:
Visit http://www.performanceproducts.co.za/
Performance Products SA
convict 66
Re: ST225 Drop in Fitment Upgrade Fuel Pumps now available
Post by convict 66 » Wed Apr 29, 2015 8:27 am
please keep us updated on your results
Umlungu
Type: White ST225
Post by Umlungu » Wed Apr 29, 2015 3:43 pm
Well considering my car wouldn't require do to the mod based on its mods I doubt whether I will see any benefit.
I need to explore a bigger turbo soon....hmmm
Pooven1979
Post by Pooven1979 » Wed Apr 29, 2015 3:48 pm
Umlungu wrote:Well considering my car wouldn't require do to the mod based on its mods I doubt whether I will see any benefit.
Umlungu, you can use my car as a demo :)
Need to get my fuel system sorted.
Free advertising space for your stickers also :lol:
Oom Piet
Type: 350R
Post by Oom Piet » Wed Apr 29, 2015 5:49 pm
What difference is there in fuel delivery / pressure between this pump and the RS fuel pump?
Dreamscience C21 Software
SAIC Intercooler
Karter Performance Boost Pipes
RS Fuel Pump
RS Turbo
RS Internals
Darton Sleeves
AS Motorsport Custom Induction
eBoost Controller & Gauge
Innovate AFR Gauge
OB1 Powered
P Dubs - C21
Post by P Dubs - C21 » Wed Apr 29, 2015 7:40 pm
Oom Piet wrote:What difference is there in fuel delivery / pressure between this pump and the RS fuel pump?
There will be no difference in pressure...
BigBear
Post by BigBear » Wed Apr 29, 2015 7:49 pm
Have you fitted DW Injectors as well ?
1978 Volkswagen Beetle 1600S
Umlungu
Type: White ST225
Post by Umlungu » Wed Apr 29, 2015 10:42 pm
BigBear wrote:Have you fitted DW Injectors as well ?
I have an open box of 550cc injectors I have thought of putting in my car but its the added issues with the software that go along with that...
The Fuel Pumps are here, I am just going to document the ease of installation for the big turbo guys.
I intend on going for a bigger turbo in the near future and thats when the injectors will slot in.
Well apparently the OEM RS pump isn't the highest flowing pump around, so either way you look at it this pump will be a massive upgrade.
If you have a big set of fuel injectors you will have a large flow demand from the pump, and if you're utilizing as much as you're flowing you will experience a massive pressure drop when the injectors open up!
Ideally you want to keep the pressure constant with no drop in boost as lower pressures means less fuel atomization by the injectors.
The guys that experiment with Ethanol mixes will know this well.
P Dubs - C21
Post by P Dubs - C21 » Thu Apr 30, 2015 6:14 am
Flow should be better yes. But to rephrase my response to OP is that the pump don't regulate pressure so the max pressure you will get will be exactly the same...
Oom Piet
Type: 350R
Post by Oom Piet » Thu Apr 30, 2015 3:31 pm
P Dubs - C21 wrote:Flow should be better yes. But to rephrase my response to OP is that the pump don't regulate pressure so the max pressure you will get will be exactly the same...
So here's how I deduce my car's components working / performance order, at 5,000 revs on 1.7bar boost the AFR is sitting at 11,5. So my fuel pump is delivering what it should. Is that correct Pat?
SAIC Intercooler
RS Fuel Pump
RS Turbo
RS Internals
Darton Sleeves
Innovate AFR Gauge
OB1 Powered
Umlungu
Type: White ST225
Post by Umlungu » Sun May 03, 2015 10:29 pm
I will throw a spanner in the works here:
As your pressure drops your fuel atomizes less, so your AFR becomes richer because the motor burns less efficiently due to time (from High RPM) and the less efficient coverage of flame front across the surface area due to an altered flame front speed from the increased density of Fuel molecules.
11.5 in my opinion sounds rich, I would have expected to see 12's in boost but you are most probably having to run rich to smother pre-ignition in the cylinders with the fuels latent heat of evaporation.
Return to “Devils Parts Discussion”
