N2MB WotBox's available
Want to sell something, this is the place to put it
Re: N2MB WotBox's available
Postby No_dachi » Wed Nov 27, 2013 7:48 pm
clutch position sensor (located behind clutch pedal) green wire on wotbox
you'll have to tap into the green and blue wire, there are three of them, look for thickest one(it also runs to all of the coil packs)
You'll have to split the cable in two, the section from the PCM gets connected to the red wire(wotbox) and the section from the coil packs gets connected to the black wire(wotbox).
Thats the RPM pickup, you want to use the black and brown wire from injector 5, you can tap into this further down the harness(yellow wire from wotbox connects onto this)
Unfortunately i cant help you with the tps, i'll have to remove my accelerator pedal to get a pic of the connection.
If your pedal is removed, step on it with the ignition on and test each wire with a multimeter until you get the correct one, it should read 0 volts with the pedal up and 5 volts with the pedal depressed.
Postby Kieren213 » Wed Nov 27, 2013 9:44 pm
Thanks dude u are a life saver I owe u big time
Postby Boolee » Thu Nov 28, 2013 8:34 am
Kieren213 wrote:Thanks dude u are a life saver I owe u big time
hope you get this thing up and running!
Postby Kieren213 » Thu Nov 28, 2013 8:37 am
It will be in tomorrow busy moving today so its going to be a hectic day
Postby Kieren213 » Sat Dec 21, 2013 6:25 pm
Good news wotbox is finally connected and working perfectly
Postby Boolee » Sat Dec 21, 2013 7:48 pm
Awesome. Who did the installation?
Postby Kieren213 » Sun Dec 22, 2013 7:41 am
bully wrote:Awesome. Who did the installation?
I did the installation myself
Postby Kieren213 » Sun Dec 22, 2013 10:18 am
If any of you guys are looking for a wotbox and installation pm me
Type: ST225+
Postby KOCkEE » Sun Dec 22, 2013 11:45 am
Mmmmm tempting to do one mmmmmmm
Postby Kieren213 » Sun Dec 22, 2013 6:15 pm
KOCkEE wrote:Mmmmm tempting to do one mmmmmmm
Its awesome dude im loving mine
Type: ST225+
Postby KOCkEE » Mon Dec 23, 2013 6:43 pm
If we ever meet take me for a drive in your ST and show me how it works it might change my mind
Postby Kieren213 » Mon Dec 23, 2013 6:45 pm
Whenever u in jozi or pta let me know and I will dude
Type: ST225+
Postby KOCkEE » Mon Dec 23, 2013 6:52 pm
Do you stay in Jozi or Pta if I'm ever in jhb I'm going a lot to jhb I'll pop you a sms then we can arrange something. You can pm me you nr then we can meet on what's app so that I have your nr.
Postby Kieren213 » Mon Dec 23, 2013 10:50 pm
KOCkEE wrote:Do you stay in Jozi or Pta if I'm ever in jhb I'm going a lot to jhb I'll pop you a sms then we can arrange something. You can pm me you nr then we can meet on what's app so that I have your nr.
Im in pta but I travel to the east rand alot
Postby donny213 » Mon Jul 31, 2017 2:46 pm
No_dachi wrote:Image
Hi can you send those pictures again or if u made a guide would be great. Thanks
Sent from my iPhone using Tapatalk
Return to Ford Sale
