K16 turbo vs Focus Rs turbo
Type: st
Postby zainpmb ST » Thu Sep 05, 2013 7:02 pm
Hi I am upgrading my turbo on my car.
Wish would be best for more power and torque
The K16 turbo or the focus RS turbo
I also have my standard K04 turbo that done 11000km its for sale if interested reply with prices
Re: K16 turbo vs Focus Rs turbo
Postby S3rategos » Thu Sep 05, 2013 7:05 pm
I wish for more power and torque too....
I'd go RS
There is no emotion; there is peace.
There is no ignorance; there is knowledge.
There is no passion; there is serenity.
There is no chaos; there is harmony.
There is no death; there is the Force.
Postby Bloubul7 » Thu Sep 05, 2013 7:10 pm
Both are the same turbos ie RS Turbo is a K16
Model: Kuga
Type: Non Burning
Postby JakeST » Thu Sep 05, 2013 7:17 pm
S60 Volvo turbo is K24 but takes alot of modding to fit....
Is a White Ricecar!!!!!!
Postby P Dubs - C21 » Thu Sep 05, 2013 8:24 pm
It's one turbo...
Type: st
Postby zainpmb ST » Thu Sep 05, 2013 8:42 pm
Thanks guys also got my old turbo If anyone is interested
Type: st
Postby zainpmb ST » Fri Sep 06, 2013 7:10 am
Is the K16 straight bolt on or do I need a new manifold and stuff
Postby Bloubul7 » Fri Sep 06, 2013 7:12 am
zainpmb ST wrote:Is the K16 straight bolt on or do I need a new manifold and stuff
Bolt on
Postby STeam » Sun Sep 08, 2013 7:31 pm
Who's doing your upgrades???
2007 FOCUS ST
MOTOCADE CAI
5 PIECE SFS BOOST PIPE KIT
BIGGER I/C
PRIMAFORCE 76MM FULL ZORST
XCEDED STG2 MAP
Postby Jostian » Mon Sep 09, 2013 12:57 am
On a stick ST250 what would be the power gain of the K16 vs K04, just asking for a best guess estimate? And other benefits of the K16 over K04, if any?
Performance Blue 2013 Focus ST
be True to Yourself...!
Model: Figo
Postby FEENIKS » Mon Sep 09, 2013 7:07 am
Jostian wrote:On a stock ST250 what would be the power gain of the K16 vs K04, just asking for a best guess estimate? And other benefits of the K16 over K04, if any?
A stock block would be your limiting factor with a K16.
The K16 can flow the same as a K04 at much less boost/strain, so there is a reliability factor.
The KO4 at a stretch can make similar power to a K16 on a moderate tune but will not last very long.
On a pump fuel conservative tune, i would imagine a k16 to make probably 30kw more than a ko4, all else being equal.
Type: ST PB
Postby radmoodley » Sun Sep 15, 2013 8:08 pm
Jostian wrote:On a stick ST250 what would be the power gain of the K16 vs K04, just asking for a best guess estimate? And other benefits of the K16 over K04, if any?
The K16 is a big step up from a K04. So gains will be big provided you can tune it on the new 4-cylinder engine in a ST250. K16 flows a lot more than a k04 for a given boost level, the first thing you may find is your fueling would need to be worked out properly lest you want to run lean
Postby Tren » Mon Sep 16, 2013 11:06 am
forgive me in assuming wrong here...
but i wouldnt use an ST k04 on a ST250 seeing as the motor is direct injection and the ST k04 is a low pressure turbo..
a k04 comparable to the vag K04s which is a high pressure turbo..would be the better type of turbo to go for on the ST250..
Make: ST
Model: 2.5
Type: turbo
Postby strate » Fri Nov 08, 2013 1:29 pm
P Dubs - C21 wrote:It's one turbo...
Do you need to change the oil and water line with this upgrade?
Or will the stock lines work?
Type: slow
Postby Stitch » Fri Nov 08, 2013 1:31 pm
I'm quite sure you would need to change your oil lines
renier_cpt wrote:
You're going to break the interwebs Samir! :lol:
Return to Focus ST Performance Mods
