two splits systems vs one split and sub
transformer
Post by transformer » Mon Feb 23, 2015 8:06 am
I am planning to do some basic sound upgrades without it breaking the bank so what I came up with is two 6.5 inch kicker components and a kicker amp. I just want better quality not really after crazy bass. Any advice?
Is the rear of the focus ST 2010 also 6.5 inch?
This is the headunit I am planning to go for:
http://www.stopshop.co.za/buy-ford-focu ... ull_site=1
the two split systems and amp
http://www.planetworld.co.za/kicker-ds- ... [email protected]
http://www.planetworld.co.za/kicker-cx3 ... @1445.html
any advice or recommendations please
Reason: Fixed URL
Xcedester225
Model: 6
Type: MPS
Re: two splits systems vs one split and sub
Post by Xcedester225 » Mon Feb 23, 2015 9:05 am
I would recommend split system in front, only mids in the rear and one 10" or 12" sub. Not needed for entire split system in the rear. Kicker a good option if looking for good sound for not that much money.
2008 Mazda 6 MPS
Ex: Stage 2 Megane 2 RS (190wkw & 420nm)
transformer
Post by transformer » Mon Feb 23, 2015 9:15 am
Ah okay I see. Reason I wanted spilts instead of a sub is because im not after bass . I Just want good quality sound thats better than stock setup
Thanks a lot tho will check out sub options maybe
DeanST
Model: Slow
Type: Slow
Post by DeanST » Mon Feb 23, 2015 9:43 am
why don't you just put 6.5 splits in front, and a sealed 10 inch sub running off a 4 channel amp.
You will get more than enough good quality sound from your splits and you will not regret the sub once you have it!
My 2c
Tren
Post by Tren » Mon Feb 23, 2015 9:59 am
^^^ Agreed..
get a 10 inch... but go for quality like a JL...wont give mind blow bass either..but that all can be set up on your amp gains etc..
you heard my car...it plays clear and loud...but too much bass for you like you said..but that can all be adjusted...
the rear stage in the ST is fine...mine is still holding up...i just have front splits... VIBE ones...
so i would suggest... front 6.5 splits... 10 inch sub.. and the amp..and you will be sorted :smt023
Boolee
Post by Boolee » Mon Feb 23, 2015 10:30 am
i hair gree. splits in front and a 10" sub. it will just sound crisp and clear, nobody is going to mistake you for a charou driving a phoenix taxi.
Tren
Post by Tren » Mon Feb 23, 2015 10:34 am
Boolee wrote:i hair gree. splits in front and a 10" sub. it will just sound crisp and clear, nobody is going to mistake you for a charou driving a phoenix taxi.
LMAO this is true :lol:
transformer
Post by transformer » Mon Feb 23, 2015 10:44 am
Lol! Ok thanks alot guys I am going for sub amp and splits!! Appreciate it
in10sive
Post by in10sive » Mon Feb 23, 2015 11:45 am
@transformer are you going to stick with the stock radio?
fuzz123
Post by fuzz123 » Mon Feb 23, 2015 11:50 am
in10sive wrote:@transformer are you going to stick with the stock radio?
transformer wrote:
This is the headunit I am planning to go for http://www.stopshop.co.za/buy-ford-focu ... ull_site=1
'09 320D Msport BMW
Ex. Ford Focus ST170 - a Slow one....
in10sive
Post by in10sive » Mon Feb 23, 2015 12:03 pm
saw that but no one mentions the radio upgrade again...in my prevouis ride I had LA setup with stock radio and it played crap - I then upgraded to Alpine HU and the sound clarity was 100x better.
transformer
Post by transformer » Mon Feb 23, 2015 12:31 pm
Im no sound guru but the headunit is the power source of your speakers if im not mistaken. so getting an external source like an amplifier would fix that. A better headunit will improve it as well. Not sure tho
PopGun
Post by PopGun » Mon Feb 23, 2015 12:45 pm
Stop shop and quality cannot be used in the same sentence from what I read before
transformer
Post by transformer » Mon Feb 23, 2015 12:56 pm
PopGun wrote:Stop shop and quality cannot be used in the same sentence from what I read before
Yeah I know this was hoping guys would advise on these newer units. I have seen some walk through videos on units with those exact specs and they seem.pretty good compared to.the older stuff? Julez has probably seen these new units in action?
in10sive
Post by in10sive » Mon Feb 23, 2015 12:57 pm
transformer wrote:Im no sound guru but the headunit is the power source of your speakers if im not mistaken. so getting an external source like an amplifier would fix that. A better headunit will improve it as well. Not sure tho
Headunits makes a huge difference (sound processing/signals etc) imo - think it is the 1st thing to upgrade before looking at speakers and amp, but thats my preference.
Return to “Focus ST Audio”
