Speaker size
Speaker size
Postby convict 66 » Thu Mar 12, 2015 1:48 pm
hi all
i just want to find out what are the speakers sizes for the front and rear aswell as tweeters in the front doors?
and will i be able to go bigger or should it remain the stock size becuase of space.
thanks nando
Re: Speaker size
Postby BigBear » Thu Mar 12, 2015 2:22 pm
convict 66 wrote:hi all
i just want to find out what are the speakers sizes for the front and rear as well as tweeters in the front doors?
and will i be able to go bigger or should it remain the stock size because of space.
thanks nando
6.5" Split System should work..
Make: .
Model: .
Type: .
Year: 1999
Re: Speaker size
Postby ambroseg1 » Thu Mar 12, 2015 2:49 pm
6.5 inch in the front and 5.25 inch in the rear if memory serves.
Tweeters by any manufacturer will fit as they are more or less all the same size I think.
This is for 225 ST.
Re: Speaker size
Postby convict 66 » Fri Mar 13, 2015 10:27 am
thanks bigbear and ambroseg
Re: Speaker size
Postby transformer » Fri Mar 13, 2015 12:33 pm
Front is def 6.5". Can anyone confirm the sizes for the rear?
Re: Speaker size
Postby convict 66 » Fri Mar 13, 2015 12:54 pm
transformer wrote:Front is def 6.5". Can anyone confirm the sizes for the rear?
googled everywhere now for the rear spec but no luck
front is def 6.5 yes
Re: Speaker size
Postby transformer » Fri Mar 13, 2015 1:09 pm
I thought it woud be 6.5 front and rear
Re: Speaker size
Postby convict 66 » Fri Mar 13, 2015 1:11 pm
transformer wrote:I thought it woud be 6.5 front and rear
no idea
check most of the st owners sites now with no luck
any one close to a ford st owners manual to check?
Re: Speaker size
Postby No_dachi » Fri Mar 13, 2015 3:23 pm
Fronts 6.5
Rears 5.25
This was on the 3 door, not sure if its the same on the 5 door.
Bear in mind the speaker and spacer is a complete unit, if you plan on using mdf for spacers then you should be able to fit 6.5's all round.
You can also cut the speaker out (if you have no plans to use it again) and fit the new speaker onto the spacer, the rear's a bit of a tight fit but you can fit a 6.5 in there.
Re: Speaker size
Postby in10sive » Fri Mar 13, 2015 3:36 pm
Wonder if it is worth it to replace the rear speakers when installing high end front split - I am planning to install a nice set of splits in the front and fade the stock rears a little, just for that bit of rear fill, but this is in my 3 door ST.
Re: Speaker size
Postby transformer » Fri Mar 13, 2015 4:41 pm
Great info there man, What exactly is mdf?
Re: Speaker size
Postby No_dachi » Fri Mar 13, 2015 10:31 pm
mdf - medium density fibreboard.
Re: Speaker size
Postby convict 66 » Sat Mar 14, 2015 8:41 am
No_dachi wrote:Fronts 6.5
Rears 5.25
thanks man :D
