ST250 Ignition dependant remote
Postby jbassonjnr » Mon Mar 16, 2015 7:03 pm
Hi all
Wanted to know, I have a huge sound install, but I am having issues with remote turn on. The can bus system has a huge impact. I want to find a Ignition dependant wire from the passenger side Fuse box, if I am not mistaken Fuse 85 is the one to use. I know you get something called a Fuse tap to add a circuit, but I can't find them at all. How do you tap into a Fuse without cutting any wires, any help will be greatly appreciated
ST is the ONLY way!!
Re: ST250 Ignition dependant remote
Postby Bloubul7 » Mon Mar 16, 2015 8:13 pm
Have a look at this thread:
viewtopic.php?f=18&t=77991&hilit=+amp+st250
You can get the fuse taps from some audio shops, otherwise you can look at using a positap (you get them from builders). I would however not recommend the positap as after some time they do tend to give some problems.
Postby jbassonjnr » Mon Mar 16, 2015 8:24 pm
Bloubul7 wrote:Have a look at this thread:
Thanks bud, appreciate the help
Postby jbassonjnr » Mon Mar 16, 2015 8:25 pm
The thread specifies the Fuse box in the back, any Fuse from the passenger side footwell instead?
Make: S
Model: T
Type: 3
Postby Mean_ST » Tue Mar 17, 2015 7:52 am
I ordered myself one of these from ebay
http://www.ebay.com/itm/261778075837?_t ... EBIDX%3AIT
Now to wait forever for it to arrive :p
Postby jbassonjnr » Tue Mar 17, 2015 7:54 am
Mean_ST wrote:I ordered myself one of these from ebay
Thanks, I managed to find a local guy, waiting for stock to come from Witbank to JHB
