ST225 Drive Fault
ST225 Drive Fault
Postby Oros1-WP » Sat Aug 05, 2017 8:54 am
Hi gents my standard head unit has been giving me some problems. If i want to play cd's it just says drive fault on the display on goes to the radio again. Has anyone else had this proble? Whats the best thing for me to do? Fix it or change to a aftermarket double din?
Sent from my SM-G925F using Tapatalk
Re: ST225 Drive Fault
Postby convict 66 » Sat Aug 05, 2017 9:33 am
the cd drive has lost its will to live
yes you can get a double din
but try check on forums or facebook or gumtree for a facelift head unit there are a few around
Type: St
Postby piper101 » Sat Aug 05, 2017 10:49 am
I had my head unit repaired once thru ford ,didn't last long.Ended up going the d/din route.
Postby Oros1-WP » Mon Aug 07, 2017 3:39 pm
Thanks guys
Postby Oros1-WP » Tue Aug 08, 2017 11:26 am
Guys ive decided to go for a double din but what size will work and where can i source a trim plate?i currently have the facelift unit which has a odd shape.
Postby Oros1-WP » Tue Aug 08, 2017 11:30 am
This is the bugger giving me headaches Image
Model: ST
Type: Focus
Postby ReinST » Tue Aug 08, 2017 4:47 pm
Hi
Autostyle has that will fit double din.
https://www.autostyle.co.za/car-audio/f ... ondeo.html
Sent from my F8331 using Tapatalk
Postby Oros1-WP » Tue Aug 08, 2017 10:00 pm
ReinST wrote:Hi
Thanks alot ReinST
