Suspension Noise When Climbing Curbs
Re: Suspension Noise When Climbing Curbs
Postby Carl231 » Thu Sep 05, 2013 11:22 am
The once off thud is something one can still live with - New problem, a vibration on the pedal, steering wheel as well as a noise, thumping noise from the front. Had the cart at the local Ford yesterday, very unhelpful - left due to that. Then went to TWT - according to them it might be CV joints or the engine mountings. Funny thing the noise/vibration is only there on bad roads and on uphill's...
Postby Carl231 » Thu Sep 05, 2013 1:19 pm
Just got word from a CV and Prop-shaft specialist here by us, took the car to him this morning - inner CV is the verdict.
Postby Torturer » Tue Sep 17, 2013 7:59 pm
Well latest is that both engine mounts and the gearbox mounts need replacing. Then they will see if Im still getting that noise or not. But with the strike at the moment not sure when they gonna phone me to come in to get the mounts replaced.
The Virus, they already replaced the wheel bearings. Would they not have applied the FMCSA fix as well? replacing the carrier and hubs sounds extreme.
1975 Ford Cortina 2.5L Big Six
2006 Ford Focus ST225 (RIP: Due to drunk MOFU)
Postby MrMazda » Tue Sep 17, 2013 8:07 pm
The Virus wrote:Hi Tortuner
I have some advice. I worked at a Ford dealer for 7 years. We had this problem on a few cars at the dealer.
The fix we had helped most of the time. The Focus ST front wheel bearing carrier doesn't have a circlip to keep the bearing in place. Its only pressfit. The fix we had was as per FMCSA to remove bearing hub from carrier, cleaning and aplying a certain Locktite compound (which I will find out) and pressing it back. Worst case is like Ash said is to replace both the carrier and wheel bearing hub!
Hope this will help. :D
I thought this was only applicable to FL models?
Postby SerialThrilla » Thu Sep 19, 2013 3:10 pm
Oh i had my noise fixed at ford last week, was a lose strut mounting, made a crap load of noise but now its all gone. Cost me R900!
cooled | mapped | inducted
LIFE BEGINS AT 250KPH
Postby Torturer » Mon Dec 16, 2013 10:29 pm
Eventually got called in to have the engine mounts replaced. Suprise suprise, noise still there after mounts fitted. Now they tell me after another "full" day of inspection that the stabilizer linkages need to be replaced. How much diagnostic testing do the dealerships actually do on our cars if they keep moving to the next part they think needs fixing...
Make: focus
Model: st
Type: ford
Postby RED BULL » Mon Dec 16, 2013 10:40 pm
Torturer wrote:Eventually got called in to have the engine mounts replaced. Suprise suprise, noise still there after mounts fitted. Now they tell me after another "full" day of inspection that the stabilizer linkages need to be replaced. How much diagnostic testing do the dealerships actually do on our cars if they keep moving to the next part they think needs fixing...
Hi Sias here normaly 80% of the time the problem is on the stabelizer bar and there is a
fix that can be done with out replacing any parts you just need to stif up the bar bushes
MAKE ME BEAT YOU
1/4 mile 12.2
1 km 257km
And no gas just kicking ****
Postby Torturer » Tue Dec 17, 2013 6:55 am
Hi Sias. Well I actually had my car at porters first and no one could tell me what the problem was, and thats when I took the car to another dealership and then they just started replacing stuff they though was causing the problem.
Make: focus
Model: st
Type: ford
Postby RED BULL » Tue Dec 17, 2013 9:46 am
Torturer wrote:Hi Sias. Well I actually had my car at porters first and no one could tell me what the problem was, and thats when I took the car to another dealership and then they just started replacing stuff they though was causing the problem.
Sorry but i am back 13 jan you can bring it in and i wil have a look at it my self
MAKE ME BEAT YOU
1/4 mile 12.2
1 km 257km
Postby Torturer » Tue Dec 17, 2013 6:14 pm
Problem is that the maintenance plan has already processed the claim for the linkages with the other dealership. Is it possible to have that claim moved to porters?
Make: focus
Model: st
Type: ford
Postby RED BULL » Tue Dec 17, 2013 11:58 pm
Torturer wrote:Problem is that the maintenance plan has already processed the claim for the linkages with the other dealership. Is it possible to have that claim moved to porters?
Yes it is
MAKE ME BEAT YOU
1/4 mile 12.2
1 km 257km
Type: St
Postby piper101 » Sat Feb 08, 2014 8:06 pm
I'm curious. What was the outcome of your noise problem??
Postby Torturer » Thu Jan 29, 2015 11:04 am
Jees. This has been a long walk. Thanks to Ash for the advise and initial help. You a cool dude for giving me the time.
The problem was eventually fixed by Pro CV and Steering in Sebenza. Big ups to Raymond and his team.
They sat with the car for 2 hours. Eventually they found that the bolts on the lower shock clamps were very slightly loose. This meant that under the right conditions the shock would move in the clamp and then move back into place later cause the thud noise. After they tightened everything, problem gone. So after 2 years and countless hours lost going to the Ford dealerships and untold tens of thousands Fraud raped from the maintenance plan replacing parts at will, it got solved by non OEM company.
Im just grateful it was something not seriously terminal on the suspension since the car is now out of plan...
Postby r0ckf1re » Thu Jan 29, 2015 11:07 am
Climbing curbs with your car :lol:
Stop doing it and your problem will go away.
Postby Torturer » Thu Jan 29, 2015 11:53 am
:lol:
Will try to...
although that noise gradually worsened so that it did not need the curb to manifest...
