RS Wheels on ST225
RS Wheels on ST225
Postby in10sive » Wed Jan 21, 2015 1:38 pm
Hi
I can get a set of RS Wheels - is it a straight fit, is the ET the same accross the 2 models, don't really want to mess with spacers etc.
Type: ST F/L
Re: RS Wheels on ST225
Postby DWJ » Wed Jan 21, 2015 1:39 pm
Yebo, straight fit
Current: 2008 Focus ST Face lift
Ex: 2006 Ford Fiesta 1.6
Postby Bloubul7 » Wed Jan 21, 2015 1:39 pm
in10sive wrote:Hi
You will need spacers for the front
Type: ST F/L
Postby DWJ » Wed Jan 21, 2015 1:41 pm
Even if the car is not dropped?
Postby in10sive » Wed Jan 21, 2015 1:42 pm
Thanks Guys
[email protected], guess gonna pass then, don't want to play with spacers btw car is not dropped
Postby Bloubul7 » Wed Jan 21, 2015 2:07 pm
DWJ wrote:Even if the car is not dropped?
Even worse when it is dropped.
Type: ST F/L
Postby DWJ » Wed Jan 21, 2015 2:15 pm
Ah ok cool, I know the guys fit spacers when their cars were dropped, didn't know it was necessary normally as well
Type: 1.8T
Postby Phantom » Wed Jan 21, 2015 2:18 pm
Get hubcentric spacers, they are okay. Not the ones from Midas which disintegrate.
Postby PoLonY » Wed Jan 21, 2015 2:51 pm
in10sive wrote:Thanks Guys
Why not?
07 Volvo C30 T5 met eish
Postby PoopandPee » Wed Jan 21, 2015 2:53 pm
just get hub centric spacers.... easy peasy
or get reps that fit
Postby in10sive » Wed Jan 21, 2015 3:06 pm
Why not?
Have seen 1st hand the **** my buddy had with his car when the spacer failed, was with him in the car, jip, it was a cheapo. Put me off from spacers since the experience - think I will rather opt for other wheel options / reps that will fit without the use of spacer.
Postby PoLonY » Wed Jan 21, 2015 3:26 pm
Why not?
I see, that's why one should use proper quality spacers.
Each to their own I guess
Postby BigBear » Wed Jan 21, 2015 3:34 pm
Phantom wrote:Get hubcentric spacers, they are okay. Not the ones from Midas which disintegrate.
Bb7's RS Rims & Midas Spacers worked well when I had the RS Rims on no issues but Long Term i guess Machined/Hub Centric Spacers would be better as it needs a bit more width.
Type: 1.8T
Postby Phantom » Wed Jan 21, 2015 4:27 pm
:smt023
After time those Midas spacers really just fall apart.
Postby DURATEC80 » Sat Apr 04, 2015 3:54 pm
Are hub centric spacers safe
2011 Ford Focus ST
Dreamscience Software
Bar & Plate Intercooler
Boostworx Intake & RS Ecu Cover
Powerflow Exhaust System
RS Oil Cooler
RS Recirculation Valve
RS Rims With H&R Spacers
H&R Springs
Poly Torque Mount
