Strange markings on brake disc
Type: ST1
Postby WalkieTalkie » Fri Nov 20, 2015 1:18 pm
Hi
Has anyone see this before. Pads recently replaced. Discs skimmed.
Model: Vito
Type: 115 CDi
Re: Strange markings on brake disc
Postby Mexican » Fri Nov 20, 2015 1:35 pm
Looks like they are warped.
Any shudder feeling on your brake padal?
2010 Merc Vito Crewbus 115CDi
2015 Suzuki SX4 AllGrip
EX:Audi S3 8P
Stealth Tuned
Type: ST1
Postby WalkieTalkie » Fri Nov 20, 2015 1:52 pm
No shudder. A minor minor vibration. Very minor. Makes a humming noise.
Postby Jono52 » Fri Nov 20, 2015 2:43 pm
Did those that skimmed tell you how much they took off? Could be that they didn't take much off.
When you put new pads in, did you give them a few km's to bed in? Being hard on new pads, depending on brand can "glaze" the pads.
Type: ST1
Postby WalkieTalkie » Fri Nov 20, 2015 9:16 pm
Hi Jono
They didn't say.
These are the pads you supplied. Weren't hard on them for about 3 days. So roughly 60km.
How do you know if they glazed?
Type: 350R
Postby Oom Piet » Sun Nov 22, 2015 6:37 pm
Usually when that happens the cause is pads that run too hot and it overheats the disc hence the discoloration of the disc.
What pads did you fit?
Dreamscience C21 Software
SAIC Intercooler
Karter Performance Boost Pipes
RS Fuel Pump
RS Turbo
RS Internals
Darton Sleeves
AS Motorsport Custom Induction
eBoost Controller & Gauge
Innovate AFR Gauge
OB1 Powered
Type: ST 250
Postby [email protected] » Mon Nov 23, 2015 8:49 am
Oom Piet wrote:Usually when that happens the cause is pads that run too hot and it overheats the disc hence the discoloration of the disc.
+1 mine did exactly the same
1996 Toyota Supra 2JZ-GTE
As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my ride. -Amen
Type: ST1
Postby WalkieTalkie » Tue Nov 24, 2015 7:33 pm
Fitted Deselra. Supplied by Jono.
Solution?
Type: 350R
Postby Oom Piet » Tue Nov 24, 2015 7:39 pm
WalkieTalkie wrote:Fitted Deselra. Supplied by Jono.
Solution?
Buy better pads, they operate better at higher temps and they keep their performance.
The discoloration is not critical, it just shows that the discs don't like the pads, you will feel that your brakes will get weaker as you use them more during one spirited driving session.
SAIC Intercooler
RS Fuel Pump
RS Turbo
RS Internals
Darton Sleeves
Innovate AFR Gauge
OB1 Powered
Postby Jono52 » Tue Nov 24, 2015 10:33 pm
First Ive seen this, I have a lot of guys using these pads, haven't had a comeback yet.
I'm way too hard on brakes so Deselra doesn't work for me, I've only seen this when pads are new and you brake too hard.
If there is no shudder and your brakes are working fine, I would suggest monitoring them and decide from there.
Give me a call anytime.
Postby Jippo » Wed Nov 25, 2015 7:24 am
Jono52 wrote:First Ive seen this, I have a lot of guys using these pads, haven't had a comeback yet.
Hey Jono. What pads would you recommend for the ST250? I only got 18k on my last set of front pads and it's time to replace :lol:
South Africans Against Dagga and Satan wrote:Leave our wors alone, Satan!
Postby Jono52 » Thu Nov 26, 2015 8:32 am
Its your budget that decides. You can get replacement pads (Deselra) or Upgrade pads (EBC) from Green stuff to Yellow stuff.
With EBC pads I would recommend upgrading your discs.
