Help with wheel sizes
Postby gerrieST » Thu Dec 10, 2015 6:32 pm
Hi guys. I need abit of help please. I am putting 20mm spacers in the front and 25mm at the back. The rims I am looking at is 18" 5x112 with a off set of 42 and is 9j's. Will they fit on my car without catching and scraping when you turn? Also keep in mind that my car have a 35mm drop.
Re: Help with wheel sizes
Postby motor1 » Thu Dec 10, 2015 8:58 pm
Your pcd is 5x108, are you resizing the rims or changing your hubs? Cos 5x112 rims will not fit.
r0ckf1re wrote:
bully wrote:lmao. when i crack doc tonight all those ous are gonna cry :lol: :lol: :lol: :lol:
I hope your; have time to get some racing in to :D
Youven
2004 Mondeo 2,0
Postby gerrieST » Thu Dec 10, 2015 10:06 pm
Made up spacers with 5x112 pcd.
Type: 1.8T
Postby Phantom » Thu Dec 10, 2015 10:31 pm
Yes they should work. Effective width and offset will be 9j ET22. Depends how low you are, how much camber you run and what tyres you run.
Postby gerrieST » Thu Dec 10, 2015 11:27 pm
Phantom wrote:Yes they should work. Effective width and offset will be 9j ET22. Depends how low you are, how much camber you run and what tyres you run.
Car is dropped 35mm all round and running 225/45/18 tyres.
Postby cyco » Fri Dec 11, 2015 10:04 am
will a 225 tyre fit on a 9J rim...
Make: Ford Mazda
Model: Fiesta RX7
Type: ST 150 FD3S
Postby Ruff » Fri Dec 11, 2015 10:06 am
cyco wrote:will a 225 tyre fit on a 9J rim...
Yes will be stretched but not too hectic, just check how much the rim will stick out of the side arch, if it sticks out to far you will have rubbing but with the stretched tires it should be fine.
Motorcade SRI
Torque Link Upgrade
Eibach Springs
Monroe Shocks
HID Fogs
BBS RS Wheels
Postby cyco » Fri Dec 11, 2015 10:09 am
so it will be stretched.... can you stretch a 45mm side wall tyre?
Postby cyco » Fri Dec 11, 2015 10:12 am
Type: 1.8T
Postby Phantom » Fri Dec 11, 2015 1:40 pm
I'd recommend you change from a 45 profile to a 40 profile. 225 will be fine if you don't want much stretch, if you do want stretch to ensure you won't rub then change to some 215/40/18's.
Postby gerrieST » Fri Dec 11, 2015 2:00 pm
Thanks for the advice Phantom.
Make: Ford Mazda
Model: Fiesta RX7
Type: ST 150 FD3S
Postby Ruff » Fri Dec 11, 2015 3:50 pm
Yeah my cousin has 225/40/18 stretched on 9.5j and looks great.
Motorcade SRI
Torque Link Upgrade
Eibach Springs
Monroe Shocks
HID Fogs
BBS RS Wheels
Make: Ford Mazda
Model: Fiesta RX7
Type: ST 150 FD3S
You can stretch 45mm side no problem, just 40 looks better.
Motorcade SRI
Torque Link Upgrade
Eibach Springs
Monroe Shocks
HID Fogs
BBS RS Wheels
Type: 1.8T
Postby Phantom » Sat Dec 12, 2015 12:52 am
+1 and the comfort difference isn't much. Once you go to 35 profile that's when it gets hard. 40 is the best of both.
Postby PoLonY » Sat Dec 12, 2015 7:05 am
225/40 Federal 595 rsr on a 10J
Stretch is minimal
07 Volvo C30 T5 met eish
