Audi Rims on a Focus - Will it work?
Postby Stonez » Fri Feb 05, 2016 2:48 pm
Attention Wheel Gurus!
Ok so I have been on the lookout for Audi Speedlines
From what I have found the specs are as follows.
18x7.5
5x112
ET: 54
CB: 57.1
And the Focus wheels are as follows
18x8
5x108
ET : 55
CB : 63.3
So now my question is -
If I add 20mm adapters - then offset will become 34? Is that correct?
And with the CB - Would I have to modify the rims themselves, or would adapters take care of that too?
What other options are there? Redrilling the wheels themselves to match ford specs?
Haven't bought anything yet, just an idea I have.
Thanks.
Re: Audi Rims on a Focus - Will it work?
Postby r0ckf1re » Fri Feb 05, 2016 3:39 pm
No
Model: 335i
Type: Sedan
Postby Icemanz » Fri Feb 05, 2016 6:06 pm
You will need to change your Hubs in order for this to work, im busy in the process of researching to change hubs to BMW.
Cause BMW have some pretty awesome OEM rims
Postby gerrieST » Fri Feb 05, 2016 7:47 pm
Are'nt these the sizes for the ST?
PCD:5x108
ET/Offset:38
CB:63.3
Mounting:Nut M12x1.50
OEM Tyre Size:225/40 R18
OEM Rim:7.5Jx18
According to this.
http://www.errolstyres.co.za/wheels
Postby Stonez » Mon Feb 08, 2016 8:49 am
gerrieST wrote:Are'nt these the sizes for the ST?
PCD:5x108
ET/Offset:38
CB:63.3
OEM Rim:7.5Jx18
According to this.
Hi Gerrie,
That might be right, I think where I got the wheel specs for the ST might have been a bit off.
Postby convict 66 » Mon Feb 08, 2016 9:46 am
can run adaptors
just be sure of offsets
Postby gerrieST » Mon Feb 08, 2016 10:00 am
convict 66 wrote:can run adaptors
Nando what be the best off set to run with 20mm front and 25mm back spacers? Also what rim width would be best?
Postby convict 66 » Mon Feb 08, 2016 10:19 am
that all depends on you Gerrie and what wheel and look you are going for
Postby gerrieST » Mon Feb 08, 2016 10:23 am
Still searching for a nice set of 5x112 mags that i like. I was told that 9j in front will catch inside the arch if I turn. And it was a 42 off set.
