Vibration ST225
Vibration ST225
Postby Oros1-WP » Thu Aug 10, 2017 2:59 pm
Hi gents i recently put in a H&R drop kit and new front shocks in my 2008 Focus ST. Since then theres a knocking noise when going through bumps and a vibration when driving over 100km/h. Any ideas what it could be or where i can go to have it checked in Cape Town??
Sent from my SM-G925F using Tapatalk
Re: Vibration ST225
Postby convict 66 » Thu Aug 10, 2017 3:17 pm
for the knocking i would check you control arm bushes
you sure they tightned up all the nuts and bolts for the vibration? check your rims if they not buckled
Re: Vibration ST225
Postby Oros1-WP » Thu Aug 10, 2017 9:27 pm
convict 66 wrote:for the knocking i would check you control arm bushes
Ive gone through the nuts and bolts they all good. And it's new rims that I have on . I'll check out the control arm bushes.
Re: Vibration ST225
Postby convict 66 » Fri Aug 11, 2017 7:51 am
also check to shock mounts
maybe wheel bearings aswell for the vibration
Re: Vibration ST225
Postby Oros1-WP » Sun Aug 13, 2017 11:44 am
convict 66 wrote:also check to shock mounts
I changed the shock mounts already with the shocks...so ill have a look at the wheel bearings. Thanks convict 66
