ST250 Cylinder head replacement
Post any Technical questions, advice or problems here
Type: ST3
Postby KHD » Thu Jan 11, 2018 11:25 am
Morning all,
My ST250 suffered a major breakdown and ended up with a cracked cylinder head. Where can I find a replacement cylinder head either than at the OEM? The company that tested the cylinder head is saying it's scrap and I need a new head.
Re: ST250 Cylinder head replacement
Postby Jeff_ZA » Thu Jan 11, 2018 1:15 pm
what caused the crack if I may ask?
Type: ST3
Postby KHD » Thu Jan 11, 2018 8:50 pm
There was a leak within the coolant system. Pressure test showed a leak on the coolant hose. This happened after a service at the oem.
Type: ST3
Postby KHD » Mon Jan 29, 2018 10:48 am
Quick update: cylinder head purchased from fraud for R17774. being replaced out of warranty.
Hopefully this will be a learning for others to get the oem to constantly check the cooling system and ensure your fluids are topped up at all times.
Make: Make
Model: Model
Type: Type
Postby [email protected] » Tue Jan 30, 2018 5:21 pm
I have one for sale at 6k. Sorry saw this too late
Sent from my Redmi 4X using Tapatalk
info[at]OutThereCustoms.co.za / OutThereCustoms.co.za
OTC Section
Postby Kay150 » Thu Feb 01, 2018 8:20 am
Geez that was an expensive lesson. Were there any signs before?
I live my life a 1/4 mile at a time
Type: ST3
Postby KHD » Fri Feb 02, 2018 8:46 am
No signs really. Car drove well, boosted when required and regulated temperature up until it started to smoke and misfire due to the crack. I don't recall other signs of deterioration really.
@Jo, Not a problem. I realize now I should have searched the classifieds more thoroughly. Only saw your post when I had already given Fraud the go ahead.
Postby Kay150 » Fri Feb 02, 2018 9:27 am
Thats a little scary.... i would have assumed that there would be some signs like the oil and water mixing or some overheating. Anyway glad you got it back on the road though.
Thanks for the heads up
Return to General Focus Tech Talk
