Engine Error Codes
Post any Technical questions, advice or problems here
Type: 350R
Re: Engine Error Codes
Postby Oom Piet » Thu Apr 16, 2009 8:44 am
Taking the car to the dealership now.
Will report on the outcome shortly.
Dreamscience C21 Software
SAIC Intercooler
Karter Performance Boost Pipes
RS Fuel Pump
RS Turbo
RS Internals
Darton Sleeves
AS Motorsport Custom Induction
eBoost Controller & Gauge
Innovate AFR Gauge
OB1 Powered
Postby P Dubs - C21 » Thu Apr 16, 2009 8:45 am
cool !
Make: .
Model: .
Type: .
Year: 1999
Postby ambroseg1 » Thu Apr 16, 2009 10:02 am
Namib_Boy wrote:I also have doubts about wiring, last week the front indicator stopped working.
I took it apart and globe was still 100's. Put everything back and indicator works again. :?
What do you guys reckon, must I return the car to stock before I take it to the dealer?
Will they be able to check for DTC's whilst I run DS software? Newbie on these things. :D
The motorplan and "modded" ST conflict was overcome by my friendship with this dealership. :lol:
return to stock. they might just replace your ecu or reflash it to stock, then you screwed as the unit wont work on the car anymore.
Type: 350R
Postby Oom Piet » Thu Apr 16, 2009 11:26 am
Just got back from Ford.
My cabbie has a P2127 error. :shock: :shock:
Guess what, it is described as follows:
Throttle / Pedal Position Sensor Switch E Low Input :? :?
Even a farking sensor on the petrol pedal, really I give up!
Anyway it is fixed now, connection was loose. :lol:
SAIC Intercooler
RS Fuel Pump
RS Turbo
RS Internals
Darton Sleeves
Innovate AFR Gauge
OB1 Powered
Postby P Dubs - C21 » Thu Apr 16, 2009 11:42 am
Namib_Boy wrote:Just got back from Ford.
Cool ! That explains the intermitent error code maybe... Ford machines can get error codes that wasn't cleared but not showing anymore... if you no what i mean :?
Make: .
Model: .
Type: .
Year: 1999
Postby ambroseg1 » Thu Apr 16, 2009 12:04 pm
another one with good news :D
Type: 350R
Postby Oom Piet » Fri Apr 24, 2009 8:08 pm
Guess what?? :shock: :shock:
Error P2127 returned! Again intermittent. :shock:
When the error is actively showing cabbie does'nt rev over 4k. :(
Dealership ordered new sensor assembly - Car is going in next Wednesday.
SAIC Intercooler
RS Fuel Pump
RS Turbo
RS Internals
Darton Sleeves
Innovate AFR Gauge
OB1 Powered
Postby Drifter » Fri Apr 24, 2009 9:21 pm
It stores the error code in what they call Freeze frame. If you reset it, it will check the error for 40 cycles, if it is still there , your MIL will switch on again.
Model: Premacy
Type: Aircon+ Hooter
Postby DTM » Fri Apr 24, 2009 9:21 pm
Jeesh when it goes wrong it goes wrong :( i had esp failure and acc reduced.but that was from a bad grounding and a fuze.its all sorted now and the car is pulling fine now.
AUDI B7 2.0T DTM
SOLD
Postby Drifter » Fri Apr 24, 2009 9:30 pm
I plugged out my throttle body and switched on the ignition before plugging it back in. Immediate MIL and "partial limp mode". Plugged the throttle bodu back in and light stayed on for about 150kms.
Type: 350R
Postby Oom Piet » Mon Apr 27, 2009 4:34 pm
Drifter wrote:It stores the error code in what they call Freeze frame. If you reset it, it will check the error for 40 cycles, if it is still there , your MIL will switch on again.
I only reset the code once with the DS? :?
The other ten times it resets by itself? :? How is that possible?
SAIC Intercooler
RS Fuel Pump
RS Turbo
RS Internals
Darton Sleeves
Innovate AFR Gauge
OB1 Powered
Postby Drifter » Mon Apr 27, 2009 5:52 pm
What I mean by the cycle, is you reset it, it will monitor the error, and then come back on. On the oterhand, maybe I am, totally confused.
Type: 350R
Postby Oom Piet » Thu Apr 30, 2009 4:00 pm
Throttle Body Sensor Assembly = R10,080 :shock: :shock:
Luckily Motorplan Pays = :D :D
SAIC Intercooler
RS Fuel Pump
RS Turbo
RS Internals
Darton Sleeves
Innovate AFR Gauge
OB1 Powered
Make: .
Model: .
Type: .
Year: 1999
Postby ambroseg1 » Thu May 14, 2009 7:50 am
Namib_Boy wrote:Throttle Body Sensor Assembly = R10,080 :shock: :shock:
has the problem been sorted out yet??
Postby Mr_G » Thu May 14, 2009 7:52 am
uh...you see, I told you I saw a silver ST, and that was in your sig...lol... :lol:
BOOOOOOOST!
