Engine Error Codes
Post any Technical questions, advice or problems here
Re: Engine Error Codes
Post by Stu » Thu May 14, 2009 8:13 am
damn thats pricey but at least you found the problem
Oom Piet
Type: 350R
Post by Oom Piet » Fri May 15, 2009 8:55 am
Finally the P2127 error code was sorted. :lol: :lol:
And guess what it had absolutely nothing to do with the throttle sensor. :shock:
So for the benefit of everybody else my battery was on its way out. :?
When the car is started in the morning the voltage drops below 9v.
9v is the threshold voltage for the all the ECU sensors, first sensor on my car that then schemes there's [email protected] in the land is the throttle position sensor.
Yippppppppppppppppeeeeeeeeeeee!
Dreamscience C21 Software
SAIC Intercooler
Karter Performance Boost Pipes
RS Fuel Pump
RS Turbo
RS Internals
Darton Sleeves
AS Motorsport Custom Induction
eBoost Controller & Gauge
Innovate AFR Gauge
OB1 Powered
ambroseg1
Make: .
Model: .
Type: .
Year: 1999
Post by ambroseg1 » Fri May 15, 2009 9:00 am
Namib_Boy wrote:Finally the P2127 error code was sorted. :lol: :lol:
:D :D :D Great stuff.
Return to “General Focus Tech Talk”
