Hesitation under full throttle
Post any Technical questions, advice or problems here
Type: st225
Re: Hesitation under full throttle
Postby lanley v3 » Thu Oct 21, 2010 3:42 pm
will give the boosters a try. But that stuff eats plugs. My stock plugs don't feel so nice compared to ngk when i was testing.
Timing pull was -9.8 +- with stock plugs. The ngk's -8 +-
Type: ex.RS Ultimate Green
Postby Daav - C21 » Thu Oct 21, 2010 3:45 pm
lanley v3 wrote:will give the boosters a try. But that stuff eats plugs. My stock plugs don't feel so nice compared to ngk when i was testing.
Is this timing pull at the same RPM range as where you feel the car is hesitating?
http://www.kwdealer.com.au
http://www.kwdealer.com.au/
Type: st225
Postby lanley v3 » Thu Oct 21, 2010 3:58 pm
no, just in general throughout the rev range.
Type: st225
Postby lanley v3 » Fri Oct 22, 2010 12:22 am
Problem figured out. :)
My full exhaust between 3000-4000rpm gives off a sound which cannot be explained. This sound was leading me to believe that there was a problem under acceleration but has no affect on performance. The fact that there was timing-pull also didn't help matters either.
Prash helped me out with this one. Thanks man :D
But i still prefer the 1-colder plugs. Feels more smoother and consistent. The timing-pull with the stock plugs was getting so bad that myself and Prash couldn't feel any torque kick in even though it was boosting fine. Just busy waiting for my new set to arrive.
Model: 325i M Sport
Type: Auto/Steptronic
Postby FaST&Furious » Fri Oct 22, 2010 5:21 am
lanley v3 wrote:Problem figured out. :)
Great stuff
Make: Ford ST
Model: 2.5 ST
Postby Punisher_ST » Thu Nov 09, 2017 1:55 pm
HI there
Please help i think i have the same problem .. did the new plugs do the trick?
Current: Punisher 2007 Focus ST , Ford Figo 14TDCI
Mods:Miltek Decat,Downpipe
Qaiffe LSD
DSCI Induction
Air Tec Cooler
Revo
ex - Toyota Runx RSi (157KW)
“A Turbo:Exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster”
Users browsing this forum: No registered users and 4 guests
