My ST250
Show off pictures of your Focus ST here
Make: Unknown
Model: Fast
Type: One
Re: My ST250
Postby socks199 » Mon Oct 03, 2016 11:23 am
Gazza wrote:Spotted the car at Wayne Gobey's a few weeks back. Looks great.
The oke there quoted me some high kw numbers 8) 8)
Yes had head bolts fitted. Hope for some Big numbers on the dyno once tuning start.
2013 focus ST.. KW unknown NM unknown
If you are behind you know it makes more than you...
:lol: :lol: :lol:
Make: Unknown
Model: Fast
Type: One
Re: My ST250
Postby socks199 » Tue Oct 11, 2016 10:04 am
The 1st dyno with forge build and new setup.
Watch this space
:lol: :lol: :lol:
Make: Mazda
Model: 6
Type: MPS
Re: My ST250
Postby wiek_mps » Fri Jan 06, 2017 11:08 am
And?
Sent from my LG-H815 using Tapatalk
______________
Mazda 6 MPS and Ford Focus ST 250
COBB TUNED
www.wiektuning.co.za
Re: My ST250
Postby PoopandPee » Sat Jan 07, 2017 4:37 pm
and den?
Make: Unknown
Model: Fast
Type: One
Re: My ST250
Postby socks199 » Wed Feb 01, 2017 9:22 am
PoopandPee wrote:and den?
Was buzy tuning and saw water level drop. So we stoped tuning and pulled the motor. found headbolts where never torqued right. So now waiting for new parts to do rebuild and start from scratch again.
:lol: :lol: :lol:
Re: My ST250
Postby PoopandPee » Wed Feb 01, 2017 9:34 am
eish good luck bra
Make: Unknown
Model: Fast
Type: One
Re: My ST250
Postby socks199 » Wed Feb 01, 2017 10:05 am
eish good luck bra
We almost back in running about a week and a half still then we can break her in again.
:lol: :lol: :lol:
Make: Mazda
Model: 6
Type: MPS
Re: My ST250
Postby wiek_mps » Wed Feb 01, 2017 10:14 am
Sorry to hear about the motor. Do you mind sharing a bit more info on the build and what parts was used? I am interested in the headbolts cause I lifted my head on the MPS around 470HP with the stock headbolts and moved over to L19 Headbolts which is good for 800hp plus. Just curious. Also are you running big turbo? Any plans on running aux fueling?
Cheers
______________
COBB TUNED
Make: Unknown
Model: Fast
Type: One
Re: My ST250
Postby socks199 » Wed Feb 01, 2017 10:26 am
wiek_mps wrote:Sorry to hear about the motor. Do you mind sharing a bit more info on the build and what parts was used? I am interested in the headbolts cause I lifted my head on the MPS around 470HP with the stock headbolts and moved over to L19 Headbolts which is good for 800hp plus. Just curious. Also are you running big turbo? Any plans on running aux fueling?
Cheers
All details of the build is in the ford projects section on the forum so can have a look there. I am running aux fuel kit and a big turbo
:lol: :lol: :lol:
Make: Mazda
Model: 6
Type: MPS
Re: My ST250
Postby wiek_mps » Wed Feb 01, 2017 10:32 am
Cheers
Had a look but it just says new headbolts and I see a coolboost WMI which I presume you going to use as aux fueling. But all cool was just curious. Kinda suck an odd that the head was not torque properly.
Good luck with the rebuild
______________
COBB TUNED
Model: Kuga
Type: Non Burning
Re: My ST250
Postby JakeST » Wed Feb 01, 2017 2:59 pm
Show your ST250 Wikus.....begin a thread 8)
Is a White Ricecar!!!!!!
Make: Unknown
Model: Fast
Type: One
Re: My ST250
Postby socks199 » Wed Feb 01, 2017 3:14 pm
wiek_mps wrote:
Cheers
Yes cool boost is just for the charge temp I have a extra 4x440cc injectors fitted so running 8 injectors on the car. Head bolts are imported from USA. Its a custom set made from L19 but Just better and stronger.
Yes kinda suck but now we doing everything and checking every step my self so will make sure it is proper this time round.
:lol: :lol: :lol:
Make: Unknown
Model: Fast
Type: One
Re: My ST250
Postby socks199 » Fri Mar 03, 2017 7:30 am
Finally got car back. Now just to break in
:lol: :lol: :lol:
Return to Focus ST Showroom
