Problems with Mod X... UPDATE
• Page 1 of 5 • 1, 2, 3, 4, 5
- lanley v3
- Make: ford
- Model: focus
- Type: st225
- Year: 2006
So I've been having problems with my car for the last 4 months.
Here's the story:
If say I'm in 4th gear and take my foot off the accelerator and bring the revs down to 2000rpm+- then I floor the gas. I can hear the turbo spooling/engine growl but as I hit 2300rpm+- there is like a flat-spot/hesitation/pause. It happens till 2600rpm+- then you can hear the engine start growling and turbo boosting.
I've checked logs and the throttle is closing big time from 86% down to 36% when the problem occurs. After 2600rpm the throttle opens up again.
When this flat-spot/hesitation/pause happens I see my peak boost does not hit 1.2bar.
So I've changed many things:
New Turbo
New MAF (cleaned it twice after replacing)
New MAP (cleaned once after replacing)
New Throttle body
New Lambda O2 sensor (did throw error code the other but hasn't come back)
I've also changed my induction from the GGR to the DSCI and ran octane as C21 suggested but still the same thing.
So someone suggested loading the older DS files from the UK. Loaded Perf+ and DSCI.
Guess what, problem doesn't happen with these maps.
I would ask DS UK but those okes are clueless and referred me to C21 so I've been constantly e-mailing him with logs and advice.
Don't know what to look into anymore.
Here's the story:
New Turbo
New Throttle body
- Frecky_D
- Make: Freckled
- Model: White
- Type: Legs
- Year: 2011
Re: Problems with Mod X???
It can't be mapping related, dude.
Otherwise EVERYONE would have this issue with MODX. I've been running MODX since who-knows-when and I've never had any issues with the mapping.
It'll be hardware related, but I have no idea what it'll be.
- lanley v3
- Make: ford
- Model: focus
- Type: st225
- Year: 2006
Frecky_D wrote:It can't be mapping related, dude.
That's why I put the ??? after the heading.
I've shown logs to Shaun and Prash. Everything looks normal except for the throttle closing.
The other thing is, do others actually look for the fault I'm having. Not exactly. This problem happens under the conditions I mentioned above. Does everybody do exactly what I'm doing you get what I'm saying?
Just don't understand why the stock map, Perf+, DSCI doesn't do it which is my other point.
I've got the DSCI induction, Radtec cooler, full 76mm exhaust.
- Frecky_D
- Make: Freckled
- Model: White
- Type: Legs
- Year: 2011
Still doesn't change the fact that it only happens to you.
I'll test it on my way home today and report back tomorrow.
Ask STock to do the same.
- Prash - C21
- Model: Focus
- Type: RS
- Year: 2010
Frecky_D wrote:Still doesn't change the fact that it only happens to you.
STock and I chatted about this on the weekend, and he doesn't seem to have any problems.
Prash
2010 Focus RS
1/4 mile = 12.765s @ 177.7 kph (MODDED)
1/4mile = 13.469s @ 175kph (100% Stock with 95RON)
1km = 241kph (MODDED)
EX 2009 Focus ST 1/4 mile = 13.6s @ 169 km/h @ Slippery Tarlton
Custom Tuned by C21 Engineering
2010 Focus RS
- lanley v3
- Make: ford
- Model: focus
- Type: st225
- Year: 2006
Think I'm gonna have a brand new car by the end of it
Eish, now Ford is suggesting I replace fuel pump, lambda sensors.
- STock
- Make: ford
- Model: focus
- Type: st
- Year: 2006
I'll do a log for you but i still have ob in from the weekend, so things may look slightly different in logs
DS Ultra-C21 Custom
DS CAI
DS exhaust
Radtec cooler
Eibach springs
RS injectors
IPD
AS intake manifold
Cooling mist WMI
13.69 on streets Sport Compact 3 2011
13.60 [email protected] King of 1/4mile 2012
226km/h on 1km @ King of 1/4mile 2013
DS CAI
DS exhaust
Radtec cooler
Eibach springs
RS injectors
IPD
AS intake manifold
Cooling mist WMI
- lanley v3
- Make: ford
- Model: focus
- Type: st225
- Year: 2006
STock wrote:I'll do a log for you but i still have ob in from the weekend, so things may look slightly different in logs
I can wait till you run the ob out. You got my bbm message right?
- Scorpion King
- Model: Focus
- Type: ST
- Year: 2006
- KevSTer
- Model: Focus
- Type: ST225
- Year: 2007
- Bloubul7
- Ek Mod Alles!
- Make: Range Rover
- Model: Evoque
- Type: Dynamic
- Year: 2013
Lanley, pm me your email addy. I will forward you my logs from the dyno on the weekend.
- STock
- Make: ford
- Model: focus
- Type: st
- Year: 2006
lanley v3 wrote:STock wrote:I'll do a log for you but i still have ob in from the weekend, so things may look slightly different in logs
yeah got your long **** msg
DS Ultra-C21 Custom
DS CAI
DS exhaust
Radtec cooler
Eibach springs
RS injectors
IPD
AS intake manifold
Cooling mist WMI
DS CAI
DS exhaust
Radtec cooler
Eibach springs
RS injectors
IPD
AS intake manifold
Cooling mist WMI
- Daav - C21
- Model: Focus
- Type: ex.RS Ultimate Green
- Year: 2010
KevSTer wrote:Have you tried putting the stock Spark plugs back
I suggested the same thing while back ...
- lanley v3
- Make: ford
- Model: focus
- Type: st225
- Year: 2006
- lanley v3
- Make: ford
- Model: focus
- Type: st225
- Year: 2006
