Problems with Mod X... UPDATE
Re: Problems with Mod X... UPDATE
Postby Scorpion King » Tue Jan 17, 2012 1:09 pm
have anyone tried replacing their accel pedal?
Type: 2.0t Quattro
Postby evolution » Tue Jan 17, 2012 1:46 pm
If yo guys are still experiencing this problem let me know
i had a car here last week with similar problem....JHB car running MODX
Do me a test if you will cause this was the problem we found
I know its a mission
fit back your stock intake and see if the problem goes away?
It did with the car we had here......
I will tell the solution via PM only!
Type: st225
Postby lanley v3 » Tue Jan 17, 2012 2:07 pm
I actually forgot I posted this thread. :lol:
I run Race+ with my mods as a daily drive nowadays.
I did find when my EGT's were hotter the hesitation/pause would be less pronounced. Have also changed from DS intake to GGR intake and visa versa and it always had the same issue.
Can you PM me please evolution.
Type: 2.0t Quattro
Postby evolution » Tue Jan 17, 2012 2:30 pm
PM Sent
Postby dave_cassidy1 » Wed Jan 25, 2012 3:00 am
evolution wrote:If yo guys are still experiencing this problem let me know
could you PM me the solution please Evolution, i'm still having this issue :(
Model: Ranger
Type: 2.2
Postby Sharkie » Wed Jan 25, 2012 7:48 am
Whats the difference by PM only and just posting the solution on here, the okes you are giving the solution to are in anyway going to tell people how the problem was solved
Pain is temporary glory lasts FOREVER!!!!
You think training is hard.......try losing!!!
"The way to the top is always uphill... It is only impossible if you walk away" - Ryno Griesel
Type: RS
Postby pistonhead » Wed Jan 25, 2012 9:57 am
+ 1
Current: Ford Focus RS - Ultimate Green
Ex: 2006 Pre facelift ST
Ex: 2008 Facelift ST 200KW plus Mod X monster
Postby dave_cassidy1 » Fri Feb 03, 2012 8:48 pm
+1, just post it up, whats the crack marrow
Postby dave_cassidy1 » Thu Feb 16, 2012 11:24 pm
this forum is quite poor, big up focus stoc uk
Make: Freckled
Model: White
Type: Legs
Postby Frecky_D » Fri Feb 17, 2012 3:31 am
dave_cassidy1 wrote:this forum is quite poor, big up focus stoc uk
Don't let the door hit you on the way out, Gov. :lol:
Make: Bring
Model: it
Type: on
Postby TwelveTweny1 Tuning » Sat May 23, 2015 8:05 am
Morning Gents
Ive read this post from the beginning to the End. Im currently sitting with a customers car experiencing similar issues. We running the following Mods
FMIC
CAI
Full Zorst
Devils Own Progressive
Forge Actuator
Forge Recirc Valve
Stage 2 Software
(Experimenting with a GFB controller)
For some reason when I plant the car at exactly 3000rpm boost drops and throttles are closing same as mentioned in the thread. Opening to 86% and dropping down to approx 25 - 35%
I have replaced the Recirc Valve to the Stock one as I thought this was the Problem. After repeating this exercise 3 times i have now agreed its not the recirc valve. Ive even installed a Electronic Boost controller to see if it would eliminate the issue. But to my surprise its still doing the same.
Could this be the Forge actuator messing me around? this is my first time working with one and im not sure how its meant to behave or set. Ive tried to do some research on the Forge actuator fitted with a yellow spring and not much info comes up except someone wanting to sell you the thing.
please any help or assistance would be appreciated.
I have done Boost Leak tests and eliminated all leaks.
Regards
Schalk - 0798827018
Bring it on!
Twelve21 Tuning
Postby German » Sat Jul 11, 2015 6:57 am
TwelveTweny1 Tuning wrote:Morning Gents
FMIC
CAI
Full Zorst
Forge Actuator
Forge Recirc Valve
Stage 2 Software
Regards
Schalk - 0798827018
Hey Schalk
Did you ever come right with this?
How did you set the actuator?
Users browsing this forum: No registered users and 4 guests
