DS and cracked sleeves
Re: DS and cracked sleeves
Postby STeam » Tue Sep 17, 2013 3:00 pm
Im fine with DS map. I considered all sw brands before making my choice. DSCI was the best for me..........power, economy and not running the risk of blowing the motor. And Im enjoying it.
But all this DalaSleeve talk makes me worried. So I had to ask.
Check my sig for mods.......is pump fuel fine to run?
Actuator still in factory position.
2007 FOCUS ST
MOTOCADE CAI
5 PIECE SFS BOOST PIPE KIT
BIGGER I/C
PRIMAFORCE 76MM FULL ZORST
XCEDED STG2 MAP
Postby Bloubul7 » Tue Sep 17, 2013 3:01 pm
Prash - C21 wrote:
Bloubul7 wrote:
Prash - C21 wrote:
IvanB wrote:
Prash - C21 wrote:Ask for proof that the DS software caused any sleeves to crack. Speak to the owners to get the truth.
DS has been tuning ST's in SA, since they arrived on these shores, including the RS. We hold the majority of the market, not the forum :)
The name calling is what it is.
1/4mile times and 1km exit speeds (which is not heavily dependent on driver) speak for themselves in 3 provinces.
Framed dyno sheets are nice, trophies are better :)
Our cars are fast enough, no need to stress the engine to go faster.
That is the biggest load of **** ever.
St's dorn have dsg boss. Ask me how I got into my friend's S3, first time, shaved 1 sec off his time? It is HEAVILY driver dependant.
That comment is for the 1km.
What difference did you make on the 1km ?
Are you really that dom? Surely the driver makes a difference on the 1km. It is still driven by the super fast DSG elbow and not red lining every gear
How big a difference do you assume gear changes make on the 1km?
Next time you run 1km take off from 50m after the start line and compare to your speed from the start line. We'll assume that 50m taken out from the equation was the time you spent looking at your GPS for directions to gears OK.
Your maths sucks as well. If I took 0.5s longer on each gear than you that means I would have lost 100m
The Peado Master
Model: S3
Type: 8P
Postby IvanB » Tue Sep 17, 2013 3:01 pm
I don't need a GPS to look for directions of gears. Ill outshift the k @ k out of you any day. Granny shifting FTL!
ImageImage Image
The Peado Master
Model: S3
Type: 8P
Postby IvanB » Tue Sep 17, 2013 3:02 pm
STeam wrote:Im fine with DS map. I considered all sw brands before making my choice. DSCI was the best for me..........power, economy and not running the risk of blowing the motor. And Im enjoying it.
I only see one issue with your mod list... the last mod
ImageImage Image
Postby mjp » Tue Sep 17, 2013 3:04 pm
bully wrote:
mjp wrote:Honestly, I see people complaining that software breaks cars. What people fail to understand is that a modded car can have breakages due to many factors and software is not necessarily the cause. It could be a host of things like detonation, bad fuel, worn parts, faulty plugs etc that can result in stressing the motor which can end up with a breakage.
also if your pistons are too small
That is a myth. :lol:
VAG Motorsport
For all your performance, wheels and stlyling requirements please check link below. Now carrying a range of wheels, plugs for the ST225/ST250 as well as suspensions for Fords.
http://www.vwgticlub.co.za/webstore/index.php
Postby Boolee » Tue Sep 17, 2013 3:05 pm
and the first one "2007 focus st" :lol:
:lol: :lol: :lol:
see corzza, that's how you behave when someone choons you
Type: RS
Postby Prash - C21 » Tue Sep 17, 2013 3:06 pm
OK then, I didn't think you were that useless.
Prash
2010 Focus RS
1/4 mile = 12.765s @ 177.7 kph (MODDED)
1/4mile = 13.469s @ 175kph (100% Stock with 95RON)
1km = 241kph (MODDED)
EX 2009 Focus ST 1/4 mile = 13.6s @ 169 km/h @ Slippery Tarlton
Custom Tuned by C21 Engineering
Make: VWFORDBMWTOYOTACHEV
Model: *****
Type: ******
Postby V.B » Tue Sep 17, 2013 3:06 pm
lol
R.W.B aka V.B
Make: Lamborghini
Model: Gallardo
Type: LP 560-4
Postby Tai » Tue Sep 17, 2013 3:06 pm
Postby Bloubul7 » Tue Sep 17, 2013 3:07 pm
Point made, it is driver dependant.
Model: ///M
Type: Power
Postby Rascal69 » Tue Sep 17, 2013 3:08 pm
Number 1 Cause for sleeve cracking is Actuators!! Dont touch the farking thing!!! if your tuner cant give decent power without touching the actuator, find another tuner! finish and kla!! that actuator bolt is a **** thing, need to use double bolt and locktite to stop it from coming loose on its own and busting your sleeves.
Type: RS
Postby Prash - C21 » Tue Sep 17, 2013 3:13 pm
LMAO, are you stationary between gear changes?
Go try it!!!
Any form of racing is driver dependent off course. It is not as big on the 1km, we have checked this at almost every visit to ODI.
Or even better, skip 2nd second gear and see the difference :)
Prash
2010 Focus RS
Model: RS3
Type: Revo 2 S-tronic
Postby nanovapour » Tue Sep 17, 2013 3:16 pm
Not stationary but obviously accelaration does suffer with sloppy gear shifts, ie - loss of momentum by letting boost drop off alot more.
Miss a shift and free roll for a bit and you have a shorter distance to use maximum acceleration, which will impact your 1km speed.
Current : Audi RS3 | REVO 2
400whp & 640Nm @ FR&R
11.9 at RaceSA event Aug 15
EX : CW Roc 2.0TSi
250wkw 507Nm @ KAR
12.5 @ 180km/h (Dragwars 2013)
12.5 @ 185.8km/h (Dragwars Invitational 2013)
241km/h - 1km @ ODI (Sept 2013)
Type: RS
Postby Prash - C21 » Tue Sep 17, 2013 3:17 pm
95RON is fine
Prash
2010 Focus RS
