new dream science software
kempie.st
Type: st
Post by kempie.st » Tue Oct 29, 2013 12:05 pm
Hi guys ,
I have just bought a dsf3000 unit with the following maps;
1. performace plus
2. race plus
3.mod a
4. mod b
5. mod c95
i have on my car st 225 , decat, std zorst , mr turbo cooler, custom cai and hot side stainless steal boost pipe. car running very strong with only these mods and now ive loaded dsci and am running the mod c95 map... is this the best map? for now or should i upgrade to a custom map or mod x?
Stitch
Type: slow
Re: new dream science software
Post by Stitch » Tue Oct 29, 2013 12:09 pm
stick with mod c95 bud
modx pulls too much timing for an everyday drive
renier_cpt wrote:
You're going to break the interwebs Samir! :lol:
Boolee
Post by Boolee » Tue Oct 29, 2013 12:09 pm
that's about the best you can do with the dsf. or maybe trackracer. modx doesn't work on the dsf.
Stitch
Type: slow
Post by Stitch » Tue Oct 29, 2013 12:12 pm
bully wrote:that's about the best you can do with the dsf. or maybe trackracer. modx doesn't work on the dsf.
+1
trackracer is your best bet
gerrieST
Post by gerrieST » Tue Oct 29, 2013 1:02 pm
Guys i'm running modX on everyday basis. How much timing pull are you guys talking about?
Bloubul7
Post by Bloubul7 » Tue Oct 29, 2013 1:03 pm
Mod-X pulls about 8 to 9 degrees
Stitch
Type: slow
Post by Stitch » Tue Oct 29, 2013 1:04 pm
gpiek wrote:Guys i'm running modX on everyday basis. How much timing pull are you guys talking about?
I pulled about -11 degrees... got worse with bad batches of fuel
P Dubs - C21
Post by P Dubs - C21 » Tue Oct 29, 2013 1:14 pm
Custom map is your best answer. Email [email protected] or [email protected]
Bloubul7
Post by Bloubul7 » Tue Oct 29, 2013 1:19 pm
P Dubs - C21 wrote:Custom map is your best answer. Email [email protected] or [email protected]
Technology I tell you, looks like the Bermuda Triangle got its own email address
gerrieST
Post by gerrieST » Tue Oct 29, 2013 1:23 pm
What will the effect be of too much timing pull? @ Pdubs, how much will a custom map set you back? And also what is the use of ModX if it pulls so much timing?
Stitch
Type: slow
Post by Stitch » Tue Oct 29, 2013 1:24 pm
modx is great for high octane juice
Bloubul7
Post by Bloubul7 » Tue Oct 29, 2013 1:25 pm
gpiek wrote:What will the effect be of too much timing pull? @ Pdubs, how much will a custom map set you back? And also what is the use of ModX if it pulls so much timing?
It makes better use of octane when added
P Dubs - C21
Post by P Dubs - C21 » Tue Oct 29, 2013 1:35 pm
Pricing is available from Shaun. If your safety parameters are intact (like all DS maps) the ecu will pull timing when knock is detected. The ECU can only pull back up to a certain amount. Mod-x will obviously perform much better with better quality fuel but if you don't have, it is still safe for the car.
gerrieST
Post by gerrieST » Tue Oct 29, 2013 1:43 pm
Thanks Pdubs. I have send an email. And if you run with wmi will modx be great then?
P Dubs - C21
Post by P Dubs - C21 » Tue Oct 29, 2013 1:46 pm
gpiek wrote:Thanks Pdubs. I have send an email. And if you run with wmi will modx be great then?
Timing pull will be less but you will have to check AFR's though.
Return to “C21 Dreamscience Discussion”
