SH3 + Ethanol = xx gain
C21 Dreamscience Discussion
Moderator: C21 Dreamscience Dealer
How many KW's does C21 fuel mod gain on Focus RS?
Poll ended at Fri Nov 01, 2013 2:12 pm
0kw
10
18%
10kw
4
7%
15kw
11
19%
20kw
5
9%
30kw
10
18%
40kw
3
5%
50kw
2
4%
55kw
6
11%
60kw
2
4%
70kw
2
4%
80kw
2
4%
Total votes : 57
Make: ST2.5
Model: 2010
Type: ST2.5
Re: SH3 + Ethanol = xx gain
Postby LOUWST » Mon Nov 04, 2013 10:19 am
Hallo
25.6 FWK = 100%
Actually passion isn"t the right word.
This is OBSESSION nothing less.
Postby Dreamscience C21 » Mon Nov 04, 2013 11:46 am
bully wrote:
Jon-T5 wrote:
P Dubs - C21 wrote:Lol. Let's use the word "assemble" instead.
What do you want to use it for?
Can your sw be adjusted for rising FRP?
I think I see where this is going :lol:
lol. I gonna need kwd for fuel mod :(
The controller is 100% universal and can be used with any size injector, fuel pump, existing sensors or added, or W/M systems, etc. It is 100% programmable on it own as an independent system to control fuel and W/M 95, E85 any mix you like.
Obviously all calculations for required flow, pressure, etc. need to be considered and your tuner can also optimise the SW to make them complementary, if not it will also work as an independent programmable system to work within what every you program it to do (comes with it own program that allows you to set it up any way you want without C21 SW).
Website: http://www.dsci.co.za
Aftermarket Speed Merchant aka KW Dealer
Postby Boolee » Mon Nov 04, 2013 11:51 am
niiiiicccceee.
sounds like a nice little gadget to have.
Model: S3
Type: A3
Postby Teeman » Mon Nov 04, 2013 2:01 pm
Is this unit only for the ST's.
Make: Renault
Model: Megane RB8
Type: 2.0T
Postby Kyle_Redbull » Mon Nov 04, 2013 2:05 pm
Too much algebra stuff lol, can guys with stock sw stock everything still see gains by fitting the SH3 without ethanol? so just using the SH3 and 95 will a person see any gains? What does it cost and try simplify this in simple English of what it does who can use what mods are required etc? I will be very keen if I get decent gains prior to sw or mods?
Current: Megane RS265 RB8
Ex: Ford Kuga 2.0TDCI AWD Titanium
Ex: Ford Kuga 2.5T AWD Titanium
Ex: Mazda 3 MPS
Ex: Peugeot 3008 2.0HDI
Make: Renault
Model: Megane RB8
Type: 2.0T
Postby Kyle_Redbull » Wed Nov 20, 2013 7:47 am
Kyle_MPS wrote:Too much algebra stuff lol, can guys with stock sw stock everything still see gains by fitting the SH3 without ethanol? so just using the SH3 and 95 will a person see any gains? What does it cost and try simplify this in simple English of what it does who can use what mods are required etc? I will be very keen if I get decent gains prior to sw or mods?
BUMP - Any news on this topic as of yet?
Ex: Mazda 3 MPS
Postby Dreamscience C21 » Wed Nov 20, 2013 4:06 pm
I Kyle, yes we do see gains just by adding it with normal fuel as well not just E85. We actually putting a kit together of all the bits and bobs needed to do the install an will post pricing of the kit soon.
In simple English it maintains adequate flow and pressure over the fuel injector so that it can atomize and be more efficient under boost as standard fuel systems are not designed for additional power and boost which is the case with both ST and RS and many other vehicles.
Postby Boolee » Wed Nov 20, 2013 4:09 pm
will we get this before christmas :D :D
Postby Dreamscience C21 » Wed Nov 20, 2013 4:23 pm
Yes :D
Postby Dreamscience C21 » Wed Nov 20, 2013 4:26 pm
Teeman wrote:Is this unit only for the ST's.
No it is universal for any car with electric fuel pump, i.e. mechanical pumps on some direct injection models will not work.
Postby Boolee » Wed Nov 20, 2013 4:27 pm
Dreamscience C21 wrote:Yes :D
woohoo.
looking forward to seeing what this thing can do for the ordinary stage 2 st.
Model: A4
Type: 1.8T
Postby Phantom » Wed Nov 20, 2013 4:53 pm
woohoo.
If I'm not mistaken, Subzero said he felt a nice difference after this mod.
2005 B6 Audi A4 1.8T
Previous:
2005 Opel Corsa Lite
Return to C21 Dreamscience Discussion
