Loading Software
C21 Dreamscience Discussion
Moderator: C21 Dreamscience Dealer
SINNER-ZN
Loading Software
Post by SINNER-ZN » Fri Nov 29, 2013 5:45 am
Wonder if anyone else has this problem so to speak? I have the DS laptop software with most of the maps and whenever i load a different map on the car i get errors.
Esp system fault then water in fuel and the engine system fault. I know the engines system fault is normal but the other two faults im at a loss.
Has anyone experienced this before???
There are no error codes on ecu when i check for faults.
Dyno Wars - Autotrix - 235wkw 502nm
Autotrix - 206wkw 432nm
RS Cold Air Induction
600X300X76 Intercooler
Prima Force Exhaust
DS ModX
DevilsOwn Water Meth
P Dubs - C21
Re: Loading Software
Post by P Dubs - C21 » Fri Nov 29, 2013 6:29 am
That's normal during a load. It erases your existing map, then load new map and then for the last few seconds it clears the error codes. That's why you don't pick up any codes afterwards.
SINNER-ZN
Post by SINNER-ZN » Fri Nov 29, 2013 8:38 am
It never did that before......just recently it came up with the esp system fault while loading and what i've noticed is when i put foot down the traction control kicks in and after a while the light flashes.
I thought it was the Maf but the ecu does'nt throw any error codes. maybe it just paranoia
Prima Force Exhaust
DS ModX
Dreamscience C21
Post by Dreamscience C21 » Fri Nov 29, 2013 10:30 am
Turn off ESP when pushing the car, the traction is limiting you to prevent wheel spin.
Website: http://www.dsci.co.za
Aftermarket Speed Merchant aka KW Dealer
Return to “C21 Dreamscience Discussion”
