Loading Software
Loading Software
Postby SINNER-ZN » Fri Nov 29, 2013 5:45 am
Wonder if anyone else has this problem so to speak? I have the DS laptop software with most of the maps and whenever i load a different map on the car i get errors.
Esp system fault then water in fuel and the engine system fault. I know the engines system fault is normal but the other two faults im at a loss.
Has anyone experienced this before???
There are no error codes on ecu when i check for faults.
Dyno Wars - Autotrix - 235wkw 502nm
Autotrix - 206wkw 432nm
RS Cold Air Induction
600X300X76 Intercooler
Prima Force Exhaust
DS ModX
DevilsOwn Water Meth
Re: Loading Software
Postby P Dubs - C21 » Fri Nov 29, 2013 6:29 am
That's normal during a load. It erases your existing map, then load new map and then for the last few seconds it clears the error codes. That's why you don't pick up any codes afterwards.
Postby SINNER-ZN » Fri Nov 29, 2013 8:38 am
It never did that before......just recently it came up with the esp system fault while loading and what i've noticed is when i put foot down the traction control kicks in and after a while the light flashes.
I thought it was the Maf but the ecu does'nt throw any error codes. maybe it just paranoia
Prima Force Exhaust
DS ModX
Postby Dreamscience C21 » Fri Nov 29, 2013 10:30 am
Turn off ESP when pushing the car, the traction is limiting you to prevent wheel spin.
Website: http://www.dsci.co.za
Aftermarket Speed Merchant aka KW Dealer
