PC installation help
Postby Josh_zn » Thu Mar 06, 2014 1:33 am
Hi Guys I need some help. I bought the PC based version from Shaz and I cannot install the application or any files. The kit came with a purple color Usb stick. My PC doesn't show the Usb when installed...I cannot see it as a drive. I've followed the instructions and I am at a loss. In disk management the Usb shows as unallocated and uninitialized. It's seems a drive path cannot be set unless I'm doing something wrong.
I have a Windows 7 professional 64bit. Also ensured that the machince was started without digital signed drivers ooption.
Please help.
Type: slow
Re: PC installation help
Postby Stitch » Thu Mar 06, 2014 8:10 am
I think possibly windows 7 could be your problem.
Try a xp machine
renier_cpt wrote:
You're going to break the interwebs Samir! :lol:
Postby Kay150 » Thu Mar 06, 2014 8:30 am
Try a clean install of Windows. Maybe try a different copy? Also, some mobos have compatibility issues with certain operating systems....what mobo are you using?
I live my life a 1/4 mile at a time
Postby Josh_zn » Thu Mar 06, 2014 8:37 am
I have a very old xp machine which I tried but the machine won't get the driver for the purple Usb stick.
What is a mobo:)?
Postby r0ckf1re » Thu Mar 06, 2014 8:43 am
It not Windows, the USB stick may be faulty.
Try a diff stick on the the same machine. How many USB ports do you have ?
Postby Josh_zn » Thu Mar 06, 2014 8:55 am
Yeah I'm hoping it's not the stick. I have 4Usb ports on my one machine and 3 on the older xp machine . I'm asking Shaz since he used the last life on it. The drive can be seen in disk management but is unallocated and not initialized... And I don't see any way of allocating.. I tried nothing happens :(
Postby Josh_zn » Thu Mar 06, 2014 9:28 am
Any reps able to help?
Postby Kay150 » Thu Mar 06, 2014 9:32 am
Mobo=motherboard. Is it just files from the usb stick that don't install? Chances are it's the stick then if it's giving issues on another pc.
Postby Josh_zn » Thu Mar 06, 2014 9:38 am
The Usb in question does install , I see my machine install the driver and it says device is ready. But it will not show up as a drive. The dsci app when launched then throws and error asking for the path to this drive.
Postby r0ckf1re » Thu Mar 06, 2014 9:47 am
http://www.sevenforums.com/hardware-dev ... cated.html
use google dude, you will find something to help you out.
* dont format your drive.
Model: Fiesta (MK7)
Postby Rockafella_ST » Thu Mar 06, 2014 10:22 am
you can activate and allocate the usb drive from disk management
14.47 @ King of ODI 2014, 190whp 342nm
14.34 @ Summer slam ODI xxx xxx
14.24 @ King of ODI 2015, 194whp 362nm
14.00 @ King of ODI 2016, 167kw 362nm
Postby Josh_zn » Thu Mar 06, 2014 3:49 pm
Resolved ...UK guys at dreamscience advised...Windows7 needs to boot up without digital driver signatures...press F8 and select from boot options.
The app with the cable finally openned and I can now see all the maps and options.
Haven't as yet connected the car and uploaded a map. Will try out tonite. My laptop is dead and can't charge...Damn Eskom load shedding:)
Type: slow
Postby Stitch » Thu Mar 06, 2014 3:52 pm
told you it was a windows 7 issue :P
