Black ST turbo conversion (Dyno sheet)
Postby P Dubs - C21 » Fri Sep 18, 2015 12:45 pm
As mentioned on Monday. The black st build is ready to receive some power. The base file as been loaded to calibrate all the sensors. This dyno run was done on wastegate pressure. The end result should be nice...
Model: S40
Re: Black ST turbo conversion (Dyno sheet)
Postby FivePot » Fri Sep 18, 2015 12:59 pm
where can we download the full uncropped dyno sheet?
Postby transformer » Fri Sep 18, 2015 1:01 pm
Awesome! Looks promising
Postby P Dubs - C21 » Fri Sep 18, 2015 1:01 pm
FivePot wrote:where can we download the full uncropped dyno sheet?
What do you want to know? A full sheet will be loaded when tuning is done. for now, use a ruler. :lol:
Postby P Dubs - C21 » Fri Sep 18, 2015 1:03 pm
transformer wrote:Awesome! Looks promising
Lets hope so :) But i kinda agree.
Model: S40
Postby FivePot » Fri Sep 18, 2015 1:05 pm
What do you want to know? A tuned sheet will be loaded when tuning is done. for now, use a ruler. :lol:
I would like to see the run duration
correction factor
date
temp
My ruler cannot measure those parameters
Postby P Dubs - C21 » Fri Sep 18, 2015 1:07 pm
correction factor
date
temp
Date was today. Ambient correction was -6%. Duration was 8 seconds
Anything else?
Model: Premacy
Type: Aircon+ Hooter
Postby DTM » Fri Sep 18, 2015 1:08 pm
Everything in C.T is -6% is this some sort of trickery?
AUDI B7 2.0T DTM
SOLD
Make: Nissan
Model: GTR
Type: 35
Postby MikeyS » Fri Sep 18, 2015 1:12 pm
Speed?
Postby Pooven1979 » Fri Sep 18, 2015 1:34 pm
P Dubs - C21 wrote:As mentioned on Monday. The black st build is ready to receive some power. The base file as been loaded to calibrate all the sensors. This dyno run was done on wastegate pressure. The end result should be nice...
Very good power delivery there Dubsie.
What do you mean: "This dyno run was done on wastegate pressure."
Postby ash » Fri Sep 18, 2015 1:49 pm
looped actuator / wastegate to snail. boots the minimum pressure the spring can allow. as the boost climbs it start releasing exhaust gasses immediately hence throwing away maximum gas causing turbo to spool and spin slower
Postby Pooven1979 » Fri Sep 18, 2015 1:58 pm
THanks Ash. I though so but wasnt 100% sure.
My car is currently set like that also...LOL
