C21 Xmas Specials
BANNED
Re: C21 Xmas Specials
Postby ClemR » Fri Feb 19, 2016 10:16 am
Tren wrote:
ClemR wrote:
Tren wrote:Contact Shaun now, things have changed, and support will be much better moving forward.
When i see it, i will believe it.
But you got Clemrosis :lol:
bra even a blind ou can see there is farkall support from DS :lol:
-Celtic Tuned ST
Forged motor and Darton Sleeved block
Garrett GTX3071
Precision wastegate
GFB 2 Controller
[i]275wkw/371whp 451nm @1.3 bar
300wkw/406whp 512nm @ 1.5 bar
304wkw @ 1.5 bar (OB1 dyno)
2015 Golf 7R(Stock)
Postby Dreamscience C21 » Fri Feb 19, 2016 11:00 am
ash wrote:if i chose to use this device - who could i use to develop a custom file for me? and how?
do i send logs to a dealer of my choice?
Do a merely send the following to get a base map?
1 - turbo spec / flow chart
2 - injector size / flow chart
3 - fuel preference - Pump gas / e50
4 - target boosts
5 - sensor types ? IE RS MAF / MAP
6 - boost pipe dia
7 - intake pipe dia
I did ask for more info regarding this to be emailed to me and have yet to receive a response -
anyone have a contact for me abroad to ask for more info? not sure if the SA boys can accomodate
Hi ash, yes you send the logs to me and your mod list and we generate a custom file or a set of files for your setup that you load on to the IMAP. It can hold 10 custom tunes.
Website: http://www.dsci.co.za
Aftermarket Speed Merchant aka KW Dealer
Postby Dreamscience C21 » Fri Feb 19, 2016 11:06 am
frozen225 wrote:Are the fogs plug and play?
Yes they are
Postby Dreamscience C21 » Fri Feb 19, 2016 11:07 am
Support is back on Track
Postby Dreamscience C21 » Fri Feb 19, 2016 11:08 am
He still have not responded to emails or PM's sent in December.....
Responded to your mail sent yesterday :D
BANNED
Postby ClemR » Fri Feb 19, 2016 11:12 am
Thats good to hear Shaun, If thats the case that is awesome news
-Celtic Tuned ST
Garrett GTX3071
Precision wastegate
GFB 2 Controller
2015 Golf 7R(Stock)
Postby Dreamscience C21 » Fri Feb 19, 2016 11:23 am
Ford_Fanatic wrote:I missed this special. Would a special like this be coming up again?
We are currently busy with a bulk buy at the moment to try bring the cost down by sharing shipment costs and getting a bulk discount, if you are interested let me know.
Postby Tren » Fri Feb 19, 2016 12:10 pm
Getting your map. You had your car on the Dyno? Figures?
226kw 490nm, but i found out my OFH diaphragm was torn from the time i moved to CT, so as i modded more i lost more power...
UK, states 330hp....
Which i most probably would've gotten had i known to replace it.
Postby transformer » Fri Feb 19, 2016 12:13 pm
Awesome stuff!
Postby Ford_Fanatic » Fri Feb 19, 2016 12:27 pm
Yes I definitely am! Price dependant of course.
Fastest On Race Day!!
Drive it like you "ST"ole it!!
Current:
2006 Ford Focus ST
2012 Alfa Mito QV Sport
2005 Ford Focus St170
2001 Golf 4 GTi (Modded)
1970 Ford Cortina XR6 Interceptor. (Modded)
Postby leon » Fri Feb 19, 2016 12:30 pm
Awesome. I want....
Postby ash » Fri Feb 19, 2016 1:32 pm
and where is my response?
I will run PT6262
750 cc injectors
RS MAP AND RS MAF
anything else i need to do or know in order to make use of you files?
what are my limits based on the criteria listed above? or advice atleast
Postby Dreamscience C21 » Fri Feb 19, 2016 1:34 pm
PM, Email I don't see it :(
Postby xStatic » Fri Feb 19, 2016 4:18 pm
Shaun are you able to create custom maps to work with the older ultra units for us that spent 9k a few years back on that unit?
400m - 14.53 @ 158km/h @ Dragwars 2011 (Dreamscience Race+ only)
1km - 227km/h @ TeamST ODI July 2014 (A bit more than Dreamscience Race+)
Postby Tren » Fri Feb 19, 2016 4:24 pm
xStatic wrote:Shaun are you able to create custom maps to work with the older ultra units for us that spent 9k a few years back on that unit?
Yip he can :smt023
