Fuel Consumption
Gerben
Fuel Consumption
Post by Gerben » Fri May 20, 2016 2:11 pm
Can DS give a economical file on a 5 pot and if yes what is economical ?
Or is this just a **** question because its a 5 pot ?
G5 REVO KO4
FOCUS ST 255
flyby
Make: car
Model: car
Type: car
Re: Fuel Consumption
Post by flyby » Fri May 20, 2016 2:16 pm
Why would you want it?
Gerben
Post by Gerben » Fri May 20, 2016 2:24 pm
If the wife is using the car, then I don't want her to roll up the streets so would a economical file help if there is such a thing for a 5pot ?
G5 REVO KO4
FOCUS ST 255
flyby
Make: car
Model: car
Type: car
Post by flyby » Fri May 20, 2016 2:28 pm
Oh ok. They have economy files but they really dont make much difference
Gerben
Post by Gerben » Fri May 20, 2016 2:34 pm
Okay cool, then it is what it is!
G5 REVO KO4
FOCUS ST 255
flyby
Make: car
Model: car
Type: car
Post by flyby » Fri May 20, 2016 2:39 pm
Your wife will prob get it lower anyway.
I get 350km from a 65 litre tank normally. If i drive craefully i can stretch it to 450. When my fiance uses my car she can get around 550km.
Dont know how she does it lol
Gerben
Post by Gerben » Fri May 20, 2016 2:55 pm
What mods are you running on your ST ?
G5 REVO KO4
FOCUS ST 255
flyby
Make: car
Model: car
Type: car
Post by flyby » Mon May 23, 2016 7:24 am
I dont have an ST any more.
As Mys says i have an Oupa wagon :D
DTM
Model: Premacy
Type: Aircon+ Hooter
Post by DTM » Mon May 23, 2016 12:54 pm
Having owned a 5 pot ST myself fuel consumption went out the door. I tried granny shifting for a week and couldn't take the pain no more even so my consumption wasn't anything to brag about. 5 pot is thirsty and with a small fuel tank in these cars that doesn't help either.
AUDI B7 2.0T DTM
SOLD
PoopandPee
Post by PoopandPee » Mon May 23, 2016 6:26 pm
yes there is an economical file, it's called keep your right foot off the go pedal....
No matter what file wah wah.... it's all about drive style
Gerben
Post by Gerben » Mon May 23, 2016 7:56 pm
They say a BT will be more efficient than oem because of the late spooling ? But also heavier if your foot is heavy.. is this true on a 5pot ?
G5 REVO KO4
FOCUS ST 255
Bloubul7
Post by Bloubul7 » Mon May 23, 2016 8:15 pm
Gerben wrote:They say a BT will be more efficient than oem because of the late spooling ? But also heavier if your foot is heavy.. is this true on a 5pot ?
Yes it is, a heavy foot means more boost which equates to more air entering the engine and thus more fuel required to in order to keep to the air/ fuel ratio required.
To explain it, when you are not boosting you car will aim to run an AFR (air to fuel ratio) of 14.7. As soon as you start boosting this ratio drops to around 11 to 12 depending. That means that you are already using 25% more fuel by just going into boost, but as soon as you start boosting the airflow will increase as well which now increases your fuel usage to around 40-50%.
flyby
Make: car
Model: car
Type: car
Post by flyby » Tue May 24, 2016 6:53 am
Its the price we pay for fun!
DURATEC80
Post by DURATEC80 » Mon May 30, 2016 11:00 pm
I think the STOC map on the ultra is thr economy map
2011 Ford Focus ST Frozen White
Boostworx Cold Air Intake
Bar & Plate Uprated Intercooler
Powerflow Full Exhaust System
RS Oil Cooler
RS Ecu Cover
Genuine 19" RS Wheels
AS Recirculation Valve
Uprated Poly Engine Mount
H&R Sport Springs
Dreamscience Software
2011 Ford Focus ST
Bar & Plate Intercooler
Boostworx Intake & RS Ecu Cover
Powerflow Exhaust System
RS Oil Cooler
RS Recirculation Valve
RS Rims With H&R Spacers
H&R Springs
Poly Torque Mount
Jon-T5
Model: R8 V12
Type: V-TEC
Post by Jon-T5 » Tue May 31, 2016 1:17 pm
Better fuel economy on a BT is bollocks purely because you're going to want to boost ALL-THE-TIME :lol:
Now, I admit that there are two distinguishing features that you can use to tell apart the Audi sedans. One is LEDs. The A4 has roughly seven, while the A8 could guide damaged ships to the mainland.
Return to “C21 Dreamscience Discussion”
