Cobb tuning
Introduce yourself here
Forum rules
Please note that all noobs are required to introduce themself in the Noobs section, failure to introduce yourself could lead to your posts being deleted without notice.
Please also make sure you familiarise yourself with the forum rules at: viewtopic.php?f=24&t=138
Type: St
Year: 2016
Cobb tuning
Postby Ford St2830 » Mon Jan 01, 2018 9:23 pm
Hi all
Happy new year to everyone.
I’ve been on a long distance trip recently with my Focus St 250 currently has a custom map stage1 and I would like to get some clarity regarding negative ignition corrections. I noticed that on the Ap I’ve seen negative values up to -4,19 under hard acceleration with the vehicle aircon on and this usually happens not immediately. It first makes positive readings up to 4,00 then falls to negative readings. Is this due to the climate. Is this a cause for concern, or is this normal under the circumstances
Re: Cobb tuning
Postby German » Wed Jan 03, 2018 6:09 am
Have a chat with your tuner about it, otherwise you can give Karter Performance a call and once of us can explain it to you next week if you'd like.
It's a lengthy explanation to type out in detail.
Sent from my ONE A2005 using Tapatalk
Type: St
Year: 2016
Re: Cobb tuning
Postby Ford St2830 » Wed Jan 03, 2018 6:53 pm
Thanks a lot guys had a chat with my tuner he explained to me the process.
He’s response was “Negative correction on part throttle is perfectly normal. That is the car trying to find mbt. That means the best advance timing with least amount of fuel for the best emissions and fuel economy. It is the way the ecu was designed. It is normal.. Mine does it aswell”
Thanks all
Re: Cobb tuning
Postby German » Thu Jan 04, 2018 5:40 am
Glad you've got your full explanation.
Just remember you said: "I’ve seen negative values up to -4,19 under hard acceleration". If under hard acceleration then the explanation holds true but means the ignition timing is way too advanced for the fuel/load/rpm. It is best to avoid any negative corrections at At wide open throttle.
Type: St
Year: 2016
Re: Cobb tuning
Postby Ford St2830 » Sat Jan 06, 2018 9:20 am
Thanks a million I really appreciate the feedback
Year: 2016
Re: Cobb tuning
Postby Blackriver » Sat Jan 06, 2018 10:08 pm
While we on COBB Tuning, what is the average gains full boltons stock turbo running ethanol.
Sent from my G3221 using Tapatalk
Re: Cobb tuning
Postby convict 66 » Mon Jan 08, 2018 7:18 am
Wiektunez can help you out with that question
Re: Cobb tuning
Postby German » Mon Jan 08, 2018 12:03 pm
Blackriver wrote:While we on COBB Tuning, what is the average gains full boltons stock turbo running ethanol.
On a Focus ST250 usually:
Stock: 155wkw/380Nm
Stage 3 E30 Custom map(Tuner and vehicle dependant): 205wkw/500Nm
Year: 2016
Re: Cobb tuning
Postby Blackriver » Mon Jan 08, 2018 4:05 pm
Precision Tuning Dyno
211wkw & 600nm
Dyno is on par with FR&R
Re: Cobb tuning
Postby German » Tue Jan 09, 2018 6:14 pm
Blackriver wrote:Precision Tuning Dyno
211wkw & 600nm
600nm? What boost you running?
FR&R centurion?
Year: 2016
Re: Cobb tuning
Postby Blackriver » Tue Jan 09, 2018 6:22 pm
24psi & 25° timing
Centurion yes
Stock was 151wkw & 380nm on same dyno
Re: Cobb tuning
Postby German » Wed Jan 24, 2018 5:34 pm
Blackriver wrote:24psi & 25° timing
Centurion yes
That is insane torque! Timing won't meant anything to me unless I know the load and RPM, either way, that's mental torque!
Nice!
Return to Noobs
