Fiesta St 1.6T Hybrid tubo options
Model: Mk7 Fiesta
Re: Fiesta St 1.6T Hybrid tubo options
Postby JDT » Thu Mar 12, 2015 11:05 am
evolution wrote:
JDT wrote:
evolution wrote:Guys
Who would be interested in this, i am in talks with someone as i have a request by a customer
In a case of mapping, i have confirmed that the STO mapping engineer will come to SA to map this specific car to suit various variables.....
Would people consider this bolt on option?
I was looking at the GTX2860R bolt on. I think price wise it will be cheaper than most hybrids and it has already been used on FiST in the states along with COBB software. There are videos on Youtube of a FiST with, I am assuming with similar turbo running 12.4 QM (he has racing slicks though).
The graphs from ATP also show around 300hp, not sure if this is on the wheels or flywheel, but I think this will also be a good option to consider.
http://www.youtube.com/watch?v=ejN0ZpWBWZo
http://www.youtube.com/watch?v=GxSWgxzy-EQ
I have personally fitted an ATP kit before NOT to A Fiesta but to a VAG 1.8T.... from my experience i rather look for a bolt on solution to offer 100% trouble free motoring! Hence the decision to look into a Hybrid
That turbo is a direct bolt on.
Product Highlights:
- Stock Location, Direct Bolt-on
- Internally Wastegated
- V-band flanged turbo adapter
- Stock turbo flanged downpipe compatible
- Stock placement intake pipe compatible. Adapter elbow provided.
- New steel braided oil feed and coolant lines provided
- Fits stock oil drain tube
- High flow charge air pipe (Product Code ATP-FIE-004) included
http://www.atpturbo.com/mm5/merchant.mvc?Screen=PROD&Store_Code=tp&Product_Code=ATP-FIE-009&Category_Code=FIE
2014 Ford Fiesta ST180 - Frozen White - Revo 1
Stock: 116wkw and 276Nm @ FRnR
Currently: 136wkw and 335Nm @ FRnR
OB1 Dyno Day: 141wkw and 350Nm @ KAR
1/4 mile:
- 15.1 @ Tarlton
- 14.51 @ ODI
Type: 2.0t Quattro
Postby evolution » Thu Mar 12, 2015 11:12 am
Product Highlights:
Nice.... has anyone done it here in SA to give feedback?
Postby Razortjie » Thu Mar 12, 2015 11:36 am
Where is PDubs? He posted photos of an ATP kit someone imported ages ago.
2014 Fiesta ST
ex: 2013 Polo GTI - Stock 14.3 @ Killarney - 139kw 259nm @ Top End
ex: 2009 Fiesta ST190+ - 142.5kw 225nm @ Dynotech
Postby Drifter » Thu Mar 12, 2015 11:40 am
News from the UK is that it makes for a horrible drive with the GTX2860R.
Type: 2.0t Quattro
Postby evolution » Thu Mar 12, 2015 11:44 am
One of my biggest concerns
Model: Mk7 Fiesta
Postby JDT » Thu Mar 12, 2015 11:46 am
Horrible in what sense?
Could you maybe quote some posts?
1/4 mile:
- 15.1 @ Tarlton
- 14.51 @ ODI
Postby PoopandPee » Thu Mar 12, 2015 11:50 am
laaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaag
Model: Mk7 Fiesta
Postby JDT » Thu Mar 12, 2015 12:08 pm
PoopandPee wrote:laaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaag
Well yes but not too much according to the dyno graphs.
Comparing my stock graph and other found on the forum the power at certain rev ranges are:
Stock
2500rpm = 75hp
3000rpm = 90hp
3500rpm = 110hp
GTX2860R
2500rom = can't compare, their graph starts there.
3000rpm = 75hp
3500rpm = 125hp
From then on it is just pull all the way.
So yes it seems that the GTX2860R will probably start spooling from 3000rpm but seeing as with Revo 2 the rev limit is set to 6800rpm, and assuming the custom tune will also be around 6800rpm to 7000rpm, that is the whole top half of the rev range with a **** load more power.
Also I don't think that while racing, from redline shifting to next gear you will drop below 3000rpm, meaning you will stay in boost.
Here is the graph from ATP
1/4 mile:
- 15.1 @ Tarlton
- 14.51 @ ODI
Postby PoopandPee » Thu Mar 12, 2015 12:12 pm
Stock
2500rpm = 75hp
3000rpm = 90hp
3500rpm = 110hp
GTX2860R
3000rpm = 75hp
3500rpm = 125hp
sounds nice if you have a weekend racing toy.
Those figures do not equate to a very nice daily drive.
Model: Mk7 Fiesta
Postby JDT » Thu Mar 12, 2015 12:23 pm
Stock
2500rpm = 75hp
3000rpm = 90hp
3500rpm = 110hp
GTX2860R
3000rpm = 75hp
3500rpm = 125hp
In traffic yes there will probably be no boost, but it will help with fuel economy staying out of boost.
But what if your daily drive is not stuck in traffic, but rather long stretches of road between robot and robot.
1/4 mile:
- 15.1 @ Tarlton
- 14.51 @ ODI
Model: Fiesta ST
Type: 1.6 GTDi
Postby chou56929 » Thu Mar 12, 2015 1:31 pm
Yea. Revo have sw for stg3 that is billet hybrid by peron
But not sure which one. There is 2 turbo, one is near 300hp, which is one i want
Ford Fiesta ST MkVII 1.6GTDi
Postby FezzST » Thu Mar 19, 2015 1:21 pm
Personally, the Pumaspeed hybrid dyno graph looks really nice. Spools the same as stock turbo and holds it for longer so torque curve stays nice and flat for nice pull up to 6000 RPM. I reckon the hybrid options might be damn near as fast as the ATP GTX (which looks horrible imo) on a strip under identical conditions. For BT, considering you want a daily drive and not just a track toy, would be the Peron EFR kit (http://www.perontuned.co.uk/products/fi ... rbo-system). It is expensive yes, but you could always get a similar setup fabricated locally (just buy turbo). There have been several comparisons and while the EFR and GTX make similar power, the EFR responds much much better because the impeller and turbine are so much lighter.
If anyone does a hybrid, would love to see the pics and graphs!
Model: Fiesta Mk7
Postby bevSTer » Mon Mar 14, 2016 4:24 pm
FezzST wrote:Personally, the Pumaspeed hybrid dyno graph looks really nice. Spools the same as stock turbo and holds it for longer so torque curve stays nice and flat for nice pull up to 6000 RPM. I reckon the hybrid options might be damn near as fast as the ATP GTX (which looks horrible imo) on a strip under identical conditions. For BT, considering you want a daily drive and not just a track toy, would be the Peron EFR kit (http://www.perontuned.co.uk/products/fi ... rbo-system). It is expensive yes, but you could always get a similar setup fabricated locally (just buy turbo). There have been several comparisons and while the EFR and GTX make similar power, the EFR responds much much better because the impeller and turbine are so much lighter.
There are 2 hybrids already...one is a stealth/pumaspeed build ----dynotech figures in CPT +- 220kw and 417nm on the fly
Other is in jozi--no power figures as yet
Postby VeloABF16v » Tue Mar 15, 2016 12:15 pm
Yoh some good power
