FIESTA ST150 PERFORMANCE SOFTWARE
Type: ST150
Postby Ben » Tue Feb 02, 2016 6:37 pm
I have looked at a couple of guys for software in Gauteng. Please give me some opinions around these guys.
RGM Motorsport
ATM Chiptunning
Steves auto clinic
Evolution Performance
CPI Tunning
Stealth Tunning
Whom would you recommend for the Fiesta ST150 With a Cosworth cam, 60mm Throttle Body, Full miltech EXHAUST, and Induction. Please feel free to recommend anyone not on my list in Gauteng.
Looking for someone in Gauteng that knows their [email protected] and that wont cause burnt valves and cause engine failures without warning lights staying on.
What is the lambda supposed to be on the 2L Duratech motor to avoid damadge to the motor?
ONCE YOU GO ST YOU NEVER GO BACK
Type: 1.8T
Re: FIESTA ST150 PERFORMANCE SOFTWARE
Postby Phantom » Tue Feb 02, 2016 10:30 pm
A Unichip tuned by a good tuner who knows what they're doing has still proven to be the best. Tuners aren't interested in developing maps for the ST150.
Postby Stu » Wed Feb 03, 2016 7:57 am
to be honest I would buy the pumaspeed map
Make: Chevrolet
Model: Sonic RS
Type: 1.4 Turbo Beasty
Postby Skywalker » Wed Feb 03, 2016 8:53 am
As much as I don't like RGM, they have a lot of experience with Unichip, I would recommend them if you go that route, there aren't many trustworthy unichip tuners these days.
Pumaspeed maps are great but you will need a DS handheld.
Either way, your car needs tuning, you will cause more damage driving it this way, without a proper tune.
Type: ST150
Postby Ben » Fri Feb 05, 2016 1:12 pm
Okay, so the booking is made at RGM for the UNICHIP.
Lets hope this goes well... But they do know what to expect and have options as to how the throttle body needs to be interfaced.
STU, Tomas from Coachmans auto sends his regards, He just serviced my car.
I Realy do hope RGM can get the car running with the 60mm Throttle Body.
Thanks for the help...
Make: Chevrolet
Model: Sonic RS
Postby Skywalker » Fri Feb 05, 2016 1:45 pm
Ben wrote:Okay, so the booking is made at RGM for the UNICHIP.
All the best & many happy miles.
Type: ST150
Postby Ben » Fri Feb 19, 2016 12:15 pm
Hi Everyone...
Okay so more questions/problems...
My fiesta is at RGM now for the Unichip and mapping for the 60mm Throttle Body.
I received a call from them saying that the throttle body standard as well as the 60mm only opens to 76% is this normal or due to the torque limiter in 1st and 2nd?
I would appreciate if someone has some info on this one for me.
Postby Stu » Mon Feb 22, 2016 9:43 am
yip that's the ecu that does that think default is like 80% you can override it with software
Type: ST150
Postby Ben » Wed Feb 24, 2016 2:59 pm
Hi guys,
Okay, so i must go fetch my fezzy at RGM soon...
What wkw and torque should i get up in JHB with cosworh cams, miltech exhaust, and induction (Duigan Brother ST180 kit) with unichip.
Also what should the Rev limiter be set at for best performance?
Type: ST210+
Postby moe676 » Wed Feb 24, 2016 9:26 pm
Ben wrote:Hi guys,
Hi Ben
I think you should expect anything from 100-105wkw and 165-175nm...these are the figures I got at KAR which isnt a generous dyno...you shouldve done a before dyno tho
With your mods I think 7200rpm should be right
Current : 05 FIESTA ST 210+
FR&R Dyno 21/03/14 : 145whp 171nm
K.A.R Dyno 07/06/14 : 107.4wkw 175 nm
FR&R Dyno 18/06/15 : 160whp 161nm
Type: ST150
Postby Ben » Wed Feb 24, 2016 10:14 pm
Cool Stuff, Thanks a milion! jip did a before dyno and was 91wkw @6500rpm
Postby mohamedeb » Sat Feb 27, 2016 12:47 am
Max rpm should be 7200rpm nothing more on stock springs
Type: ST150
Postby Ben » Sat Feb 27, 2016 11:13 am
Okay so the car now makes 100 wkw up in JHB with the standard throttle body. not going to battle with the 60mm any more. rather going to do the UDP kit...
Now my question is who will be able to up my rev limiter for me? just need to be able to reach power peak before the limiter comes in. at 6500rpm the power is still klimbing dont think i will need more than 7200 as the power wil be coming down.
