Ozzie st150 exhaust
rositano
Model: fiesta
Type: st 150
Ozzie st150 exhaust
Post by rositano » Wed Mar 30, 2016 1:21 pm
Hi guys,
I realise that much has been spoken about the 'ideal exhaust'. I've read as much as I could of different exhaust setups, but none exactly like mine (I could be wrong). Was wondering whether my setup is holding me back with regards to too much/little back pressure?
I've attached an image below of my current setup: 4-2-1 swr headers, high flow cat (200 cell), 57mm straight-through resonator, and the rest is stock.
I've kept the cat because here in Australia it's a requirement, is this the case in South Africa?
Thanks in advanced.
The attachment exhaust.jpg is no longer available
The attachment side.jpg is no longer available
V6 Capri
Re: Ozzie st150 exhaust
Post by V6 Capri » Thu Mar 31, 2016 9:56 am
Not a lot of ST150 members left on the forum.
I am sure Stu will comment when he checks in again? He has done some research on the exhaust side of things with ST150's.
1964 Ford Anglia 997cc
1972 Ford Capri 3000GT
1994 Ford Escort Cosworth (replica)
1996 Ford Escort MK6 Zetec Turbo
rositano
Model: fiesta
Type: st 150
Post by rositano » Thu Mar 31, 2016 10:27 am
That makes sense!
The st150 is a good 10 years old now i guess.
A lot of the exhaust related posts that I've read were stu's....he appears to be the exhaust guru!
KnightLion
Type: ST 150
Post by KnightLion » Thu Mar 31, 2016 11:12 am
No the Cat isn't so much an issue in SA, from what I have read and learned is 52" is ideal for the ST150 running that setup myself and have no issue with it
07 Fiesta ST
60mm TB
Motorcad SRI
SWR Branch + Powerflow exhaust
Strutbrace
Triple R front splitter and rear diffuser
Eibach Lower Springs
Poly Mount
Razortjie
Post by Razortjie » Thu Mar 31, 2016 11:14 am
I ran 57mm pipe from the ceramic coated header, no cat, small box just before the rear axle and a 500mm long x 100mm wide round rear box.
Made decent power and didn't sound bad... but I am at sea level. :)
Just remember a lot of the exhaust posts on this forum might be related to the guys in JHB... ie > 1000m above sea level.
They tend to prefer smaller diameter pipes due to the altitude.
2014 Fiesta ST
ex: 2013 Polo GTI - Stock 14.3 @ Killarney - 139kw 259nm @ Top End
ex: 2009 Fiesta ST190+ - 142.5kw 225nm @ Dynotech
rositano
Model: fiesta
Type: st 150
Post by rositano » Thu Mar 31, 2016 11:28 am
KnightLion wrote:No the Cat isn't so much an issue in SA, from what I have read and learned is 52" is ideal for the ST150 running that setup myself and have no issue with it
Yeh, I thought so. A lot of guys on this forum mention they have decats. Unfortunately (or fortunately, depending which way you look at it) here in Oz its a legal requirement.
By 52" pipe do you mean 52mm?
KnightLion
Type: ST 150
Post by KnightLion » Thu Mar 31, 2016 11:30 am
Lol my bad yes 52mm
07 Fiesta ST
60mm TB
Motorcad SRI
Strutbrace
Poly Mount
rositano
Model: fiesta
Type: st 150
Post by rositano » Thu Mar 31, 2016 11:31 am
Razortjie wrote:I ran 57mm pipe from the ceramic coated header, no cat, small box just before the rear axle and a 500mm long x 100mm wide round rear box.
That's interesting. I've noticed many guys mentioning altitude as a factor! Does it make that much of a difference if one was to stick with the stock 54mm if at sea level? Is it affecting high end hp or low end torque?
Razortjie
Post by Razortjie » Thu Mar 31, 2016 11:42 am
Probably depends how far you are modded or are going to mod if it is worth changing your setup.
Remember, we talking about tiny gains on the NA motor.
I was running the cossie cams, 60mm throttle body, UDP, k&n SRI, software, etc.
If less modded, probably very little difference between full exhaust and stock rear section.
At sea level, I would definitely recommend going 57mm all the way through if you chasing that extra 1-2kw.
The cars with full exhaust made more power at the dyno days way back when :)
2014 Fiesta ST
rositano
Model: fiesta
Type: st 150
Post by rositano » Thu Mar 31, 2016 11:59 am
Razortjie,
That's a tight setup you've got there! I don't plan on going that far for the time being.....famous last words! lol
I currently only have:
- simota enclosed sri with dual cod air feed
- swr 4-2-1 headers
- high flow cat
- 57mm resonator after cat
- bluefin stage 2
My short term goal is to get the exhaust right. My gut feeling is that it's a little restricted, and robbing me of a few ponies, but I know that if i go 57mm all the way, add a high flow rear muffler then the sound goes up....and that's another long discussion that I've seen many times before on the forum.
What's your exhaust sound like, volume-wise?
YellowSTripes
Post by YellowSTripes » Thu Mar 31, 2016 1:18 pm
rositano wrote:Hi guys,
AUSSIE AUSSIE AUSSIE!!!! OI OI OI!!!
Cant believe this true ](*,) so all the Focus 225 down under sound like pop corn machines? :lol:
rositano
Model: fiesta
Type: st 150
Post by rositano » Thu Mar 31, 2016 1:49 pm
Ha ha ha!! Nice chanting!!
Legally, we need to have a cat, but of course heaps of guys don't. They just put one on when the car has to pass registration each year.
YellowSTripes
Post by YellowSTripes » Fri Apr 01, 2016 9:08 am
rositano wrote:
Mr Wayne wrote:
rositano wrote: Ha ha ha!! Nice chanting!!
hahaha oh I see, kind of like half the guys on here with their mods and warranties :lol:
rositano
Model: fiesta
Type: st 150
Post by rositano » Fri Apr 01, 2016 11:36 am
Exactly!! Nothing like living on the edge!
Mr Wayne, do you much about st150 back boxes? Noticed a lot of guys in SA have the milltek exhausts with a free flowing back box, but I recall Stu saying that it isn't a straight-through as such. I'm keen to buy a local brand of back box which is similar in design to the milltek, but without the price tag (shipping is a [email protected]!)
YellowSTripes
Post by YellowSTripes » Tue Apr 05, 2016 8:22 am
quote]
Thanks[/quote]
I drive a 225 bud so I'm not to clued up on the 150, i will say that Stu has one of/if not the fastest 150 on SA roads at the moment so he is pretty much on point when it comes to the fiST!
Locked
Return to “Fiesta ST Performance Mods”
