Fitting a Cone Filter to an ST150
Make: S
Model: T
Type: 3
Re: Fitting a Cone Filter to an ST150
Postby Mean_ST » Sun May 17, 2009 9:11 am
Jacques wrote:
meanst wrote:just wondering can i pull the original pipe off then push it back again or do i have to make the clamps loose?
i want to run the cone filter but just be4 service i want to pluck the original stuff back.
i am keen on running the KN 57i kit
once you have done it it takes 20mins to go from KN57i to stock and then 20min back to KN57i
I changed mine twice and i still had the original clamps etc in place when i traded her in ;)
how did you keep the original clips on?
Make: ...
Model: ...
Type: ...
Postby Jacques » Sun May 17, 2009 9:19 am
easy :D
original clips are removed and kept in place on pipes with the pipes being taken out.
then you use the clamps provided with the KN kit.
so easy ;)
Make: S
Model: T
Type: 3
Postby Mean_ST » Sun May 17, 2009 7:03 pm
true but how did you remove the clips in the first place?
Postby Stu » Mon May 18, 2009 6:28 am
with a screw driver
Make: S
Model: T
Type: 3
Postby Mean_ST » Mon May 18, 2009 2:55 pm
A screw driver please elaborate
Make: ...
Model: ...
Type: ...
Postby Jacques » Mon May 18, 2009 4:51 pm
just check in your engine bay mate ;)
they clip in place...
the KN kit - those tighten with screwdriver.
Make: S
Model: T
Type: 3
Postby Mean_ST » Thu May 21, 2009 9:40 am
another ques will the fillter get wet if i drive in the rain
Postby Stu » Thu May 21, 2009 10:02 am
nope and even a little water on the filter wont have much effect except give you a little extra power as it cools the air down more LOL as long as the filter isnt drenched you should be fine
Make: S
Model: T
Type: 3
Postby Mean_ST » Thu May 21, 2009 10:05 am
ok thanks Stu
Postby Stu » Thu May 21, 2009 10:09 am
no probs mate
no probs mate
no probs mate
no probs mate
no probs mate
Postby Stu » Thu May 21, 2009 10:10 am
no probs mate
