St180 downpipe
Model: fiesta
Type: st
St180 downpipe
Postby beast1 » Sat Jul 22, 2017 11:29 pm
Hi guys
Which downpipe works best for these cars, 63mm or 76mm?
Not planning to go beyond intake, dp and software.
Could you share gains achieved by adding the dp?
Thank you
Sent from my SM-P601 using Tapatalk
Re: St180 downpipe
Postby PoopandPee » Mon Jul 24, 2017 11:58 am
63mm is good enough
Re: St180 downpipe
Postby MoltenMikeST » Mon Aug 07, 2017 6:46 am
Kater did tests without sw with dp only. Saw gains of 2.5kw and 8nm on 63mm and 2.6kw gain but 5nm loss on the 76mm dp
Sent from my iPhone using Tapatalk
Model: fiesta
Type: st
Re: St180 downpipe
Postby beast1 » Wed Aug 09, 2017 10:32 pm
PoopandPee wrote:63mm is good enough
Model: fiesta
Type: st
Re: St180 downpipe
Postby beast1 » Wed Aug 09, 2017 10:35 pm
MoltenMikeST wrote:Kater did tests without sw with dp only. Saw gains of 2.5kw and 8nm on 63mm and 2.6kw gain but 5nm loss on the 76mm dp
Thanks for this. Leaning towards the 63mm. Would the result be different with a stage 2 file?
Will get it done once the recall is done
Model: A3 Sedan
Type: 1.8 TFSI S-Tronic
Re: St180 downpipe
Postby ewieST » Thu Aug 10, 2017 2:28 pm
Stick with 63mm it will work just as good with stage 2
Sent from my LG-H815 using Tapatalk
Now: 2014 Lotus Grey Audi A3 Sedan 1.8 TFSI S-Tronic
Then: 2012 Candy White VW Scirocco 2.0 TSi DSG
2013 Fiesta ST 180 Molten Orange
Model: fiesta
Type: st
Re: St180 downpipe
Postby beast1 » Fri Aug 11, 2017 10:07 pm
ewieST wrote:Stick with 63mm it will work just as good with stage 2
Cool
Thank you
