Dario S14 200sx with ??? Power!
Re: Dario S14 200sx with ??? Power!
Postby dariodpg » Sun Apr 05, 2015 8:12 am
Work started on getting rezlo's old track car setup into tigger.
The cuts are rough and not final - lots of neatening up to do.
So the intercooler has its own brackets at the bottom, and is part of the front structure, which will reduce the risk of that top section moving around at high speed (the hood clips will still be used anyways)
may just get away with fitting this awesome setup. engine just needs to go a bit more back. and the fans need to be very slim. but looking good so far.
lights fit on nicely aswell so working well. tried to move it as far forward as possible.
Parts supplied by www.rezlo.com
Postby V6 Capri » Tue Apr 07, 2015 9:25 am
Nice updates! What else do you have of Rezlo? He has built some monsters too!
Beste resep in die wereld! 1L Ford, 2L Ford & 3L Ford!!
Image+Image+Image
Postby dariodpg » Tue Apr 07, 2015 9:54 am
V6 Capri wrote:Nice updates! What else do you have of Rezlo? He has built some monsters too!
Running the cooling system and fuel system off the ex race car. Basically 80% of the parts I got from him except the other stuff i got of my other friend with the v8 turbo lexus in rustenburg (hennie).
Postby dariodpg » Fri May 01, 2015 7:20 am
removed the stock twins. very bulky and heavy, but very advanced for its time.
Postby P Dubs - C21 » Fri May 01, 2015 7:47 am
Getting there nicely!
Postby dariodpg » Fri May 01, 2015 12:41 pm
Thanks Dubs
Turbos out
Huge, and complex
Postby dariodpg » Fri May 01, 2015 12:44 pm
My manifold options
Left - Cast large runner
Middle - Branched twin scroll
Right - OEM supra
Postby dariodpg » Fri May 01, 2015 12:53 pm
The branch manifold:
Good
1. The brake booster will be able to fit now.
2. The master cylinder for the clutch will fit now.
3. Lots of room in the bay with this unit.
4. Manifold fits the pitch of bolts well.
Not so good
1. In order for the manifold to fit: remove the thermostat housing, that is not a problem I can redirect the flow with a modification. Had to remove the wiring harness bracket, no problem.
2. I had to remove the lower row of studs, the manifold was fouling up on the bolts and it could not sit flush. No problem can get shorter studs and it will work.
3. Modifications must be made to the dump valve pipe extension, no problem this can be done. The one problem when the turbo is fitted we have a fouling condition, the electrical box must move out of the way. The turbo will sit close to the firewall.
4. The turbo needs more room, the fuse box must move out.
Postby dariodpg » Fri May 01, 2015 12:57 pm
Mock fitment
Postby V6 Capri » Fri May 01, 2015 5:23 pm
That looks proper!
Good work so far.
Image+Image+Image
Postby dariodpg » Sat May 02, 2015 10:22 am
weight of the stock turbo setup 38.95kg
weight of the new setup (Turbo manifold wastegates) 24.75kg
Postby fuzz123 » Sat May 02, 2015 10:27 am
dariodpg wrote:weight of the stock turbo setup 38.95kg
39kg's :shock: that is heavy sho!!
'09 320D Msport BMW
Ex. Ford Focus ST170 - a Slow one....
Postby dariodpg » Sat May 02, 2015 10:46 am
It is! but they work very well, especially if you mod them to accept the gt28 wheels
Heres so of the test fits, had to move out the fuse box for the time being
Postby dariodpg » Sat May 09, 2015 2:32 pm
Removed the engine wiring from the stock 2jz afm setup
Top half of intake manifold off
Engine bay starting to take shape
Make: Ordie
Model: A1
Type: Q
Postby Mad Dog » Sat May 09, 2015 5:51 pm
Wow, looks awsum. Glwtb
