Dario S14 200sx with ??? Power!
Re: Dario S14 200sx with ??? Power!
Postby P Dubs - C21 » Sat May 09, 2015 6:13 pm
Looking good man!
Postby dariodpg » Sat May 09, 2015 7:45 pm
thanks guys, also managed to remove the ABS unit. so progress is happening.
Parts supplied by www.rezlo.com
Postby dariodpg » Mon Jun 01, 2015 8:52 am
Manifold in need of a clean
Getting there
The 2jzgte injectors are for sale 6x440cc of a running car.
Postby BLESSED-ZN » Mon Jun 01, 2015 10:27 am
**** man. this build is awesome. will defs be following this thread. so keen to see her finished.
Current:2007 FIESTA ST150 silver
ex: 2009 Focus ST performance blue
ex: 2007 FOCUS ST electric orange
ex: 2007 FOCUS ST frozen white
ex: 2008 FIESTA ST frozen white
214WKW & 497NM
powered by "TWELVE21 TUNING"
Postby V6 Capri » Mon Jun 01, 2015 11:01 am
Nice and clean! How long have you been at this build?
Beste resep in die wereld! 1L Ford, 2L Ford & 3L Ford!!
Image+Image+Image
Postby dariodpg » Mon Jun 01, 2015 11:43 am
Thanks Guys, Jip Blessed, also hoping to get it done soon.
@ Capri
- Bought in October 2009
- Started engine swap in December 2013 (so it will be two years in Dec 2015)
The longish timeline, has been due to
- Parts prices, had to source some rare parts that also took some time
- Undoing alot of the initial bad work, which was limited to the engine bay gladly
Postby V6 Capri » Mon Jun 01, 2015 11:49 am
Wanted to say it is taking long... But yeh, undoing previous "mods" is a time consuming job!
Looking forward to seeing this car run!
Image+Image+Image
Postby dariodpg » Mon Jul 06, 2015 7:53 am
This weekend the front suspension striping started, which was a good move, the front wheel bearings needed to be changed (i will post the part numbers)
Did the final adjustment on the mounts, the block mounts are changing slightly as the adjustment on the ones which i bought was maxed out.
heres an idea of the engine position
- you cannot go any further back without cutting the firewall, and on the s14 that involves the relocation of many many critical items. ive got good clearance for the lines and the swaybar now. cannot believe how far off these mounts were, at least it was a decent starting point, the gearbox mount was 40mm too low :shock:
Level at the bottom
Level from back to front
Space to firewall
Space for Bellhousing
Adjustment required on gearbox mounts
Postby Stu » Mon Jul 06, 2015 8:12 am
looking Good mate :smt023
Postby V6 Capri » Mon Jul 06, 2015 9:05 am
It is getting there... well done!
Image+Image+Image
Postby dariodpg » Mon Mar 06, 2017 6:51 pm
So its been slow but some progress. haven't been updating the forums so here goes.
I Changed ECU's now looking to run the link G4 Thunder - Sold the Link g4 Extreme
http://www.linkecu.com/products/wirein-ecus/g4-thunder-ecu/
This is the link to the link features.
Postby dariodpg » Mon Mar 06, 2017 7:02 pm
So I decided to change turbos. More of an opportunistic move. went from the s366 to a 6466 about the same power with just a bit more spool. kind of regret the s366 as it was a very unique setup they way it ended up. but anyways
this is it still boxed haven't test fitted it as yet.
Postby dariodpg » Mon Mar 06, 2017 7:17 pm
I also decided to get rid of the r154 Supra gearbox, was also a sad moment because of the thought that went into that setup.
Anyways decided to go the 6spd route with a 370z box lets us hope that the box holds the power. it should shift a lot smoother and quicker. I needed it as the ECU will do flat shifting and rev matching
Postby dariodpg » Mon Mar 06, 2017 7:19 pm
so this is a picture of the setup together. the box barely fits in the sx chassis and will require some bracing. its a very very big box.
Postby dariodpg » Mon Mar 06, 2017 7:21 pm
As one can see I need to get a new flywheel machined and the clutches resplined for it to work with my tilton setup.
Users browsing this forum: Google [Bot] and 2 guests
