Project - BigBear ST
Re: Project - BigBear ST
Postby BigBear » Fri Jul 18, 2014 12:45 pm
Rockafella_ST wrote:Sjoe, really good power - why is graph so jumpy mid-range?
Not sure either Timing Pull or something on dyno...
Will check Logs and see..
1978 Volkswagen Beetle 1600S
Postby Pooven1979 » Fri Jul 18, 2014 1:56 pm
Is that a "off the shelf" map or custom tuned?
Postby BigBear » Fri Jul 18, 2014 2:45 pm
It is revo stage 2 generic map for ST 225 ...
Might have been dyno as it barely pulled 1/2 degree of timing on dyno and max boost 1.3 bar with ambient temp of 18 deg and intake 23 deg
Postby Pooven1979 » Tue Jul 22, 2014 1:12 pm
oh ok. but thats why custom tuning a map is beneficial. Good luck though!
Postby BigBear » Fri Aug 08, 2014 2:12 pm
my OB1 Review REVO2 Stock Turbo ST 225 :lol:
Improved my best Figures for my Stock ST Turbo REVO2 @ FR&R Dyno with OB1
REVO Stage 2
76mm Full Exhaust
SAIC Cold Side Boost Pipe
SAIC Intercooler
Elevate Hot Side Boost Pipe
SAIC Turbo-RIP Pipe
Dreamscience DSCi Custom Top Mount
BMC Filter
Although Some changes to Dyno (Calibration etc) and Car (Boost Leaks etc) where made in between..
Before 197 wkw after 206 wkw
Can Feel the Force !
:lol:
2013/07/04 FR&R Tuning South Africa (838) - other OB
Power: 263.1 Hp @ 5062 rpm
Torque: 453 Nm @ 3143 rpm
Power: 267.1 Hp @ 5109 rpm
Torque: 455 Nm @ 3280 rpm
2014/07/31 FR&R Tuning South Africa (998) - OB1 Fuel the Force !
Power: 278.4 Hp @ 4928 rpm
Torque: 418 Nm @ 4283 rpm
Power: 276.7 Hp @ 4770 rpm
Torque: 422 Nm @ 4389 rpm
Will do a proper comparison with Dyno and ST to be stable now it seems.. 8)
Postby Bloubul7 » Fri Aug 08, 2014 4:03 pm
Cant compare 838 to 998
Postby Tren » Fri Aug 08, 2014 4:11 pm
Bloubul7 wrote:Cant compare 838 to 998
you beat me to it lol...
838 wont take advantage of the fuel you are running..that is pump fuel settings..
Postby BigBear » Fri Aug 08, 2014 8:48 pm
was pulling timing on dyno with OB and 838 pulling less now with OB1 and 998.. like i said will do proper comparison later
Postby BigBear » Mon Mar 02, 2015 7:49 am
Update:
Recent Dyno at FR&R
Now on 178k KM but having this weird issue lately where the car would just shut down ..
Happened on the highway once and sometimes while turning not sure if this might be battery as it is 2-3 years old :?
She went into limp the other day (throttle non responsive and won't rev up) because of this and struggled to get her running with SPS and Clearing Faults which there wasn't any strange enough, after trying a few settings managed to start again.
Also have this irritating Exhaust/Suspension Rattle at the rear might need to take to Ford/ACT to have a checkup done.
Postby ash » Mon Mar 02, 2015 8:15 am
BigBear wrote:Update:
Recent Dyno at FR&R
i also had my car cutting out. the battery terminal was loose
Postby Bloubul7 » Mon Mar 02, 2015 8:18 am
I highly doubt that it is dead battery
I would think it is either a loose/ faulty connector or bad grounding.
Start by cleaning all of your grounding points with a electrical contact cleaner. Go through the wiring of the main connectors and give all of them a good clean as well. Make sure that all of your connectors are properly plugged in.
For the rear rattle check the exhaust hangers and rear sway bar rubbers
Postby BigBear » Mon Mar 02, 2015 11:16 am
Tx. Will have a Look.
Postby BigBear » Fri May 15, 2015 3:43 pm
Update:
180,000 KM Service Done
Oil Change:
Out with the Old Shell Helix Ultra 5W40, In with the New Red Line 5W30 Oil..
Oil Filter:
OLD (GUD M43)
NEW (FORD)
Pollen Filter Changed..
Best Fuel Economy yet..
182,252 KM - Battery replaced
OLD:
RAYLITE SILVER CALCIUM
651C - 12V 63 Ah 520A (IEC)
NEW:
ATLASBX - MF57220
652 - 12V 72 AH (20 HR) 130 MIN (RC) 610A (EN)
Postby GAZA5GP » Fri May 15, 2015 4:17 pm
Baie Baie Mooi Mnr!
Make: Opel
Model: Corsa
Type: OPC
Postby Wernher » Fri May 15, 2015 4:19 pm
Also did My minor service now,they also replaced my Oil and Oil filter.
My fuel consumption also went down about 1-2 l/100km
It always reminds me how important good clean oil is.
