If the clutch pedal goes to the floor
Model: Focus Silly Thing
Type: 5DR
Postby No Fat Chicks » Mon Jan 26, 2015 1:39 pm
need some help
If the clutch pedal goes all way to the floor and never returns what might be an issue here ? also discovered some broken plastic pieces on the side of the pedal floor
Money may not buy happiness, but I'd rather cry in a Focus ST than on a bus
Re: If the clutch pedal goes to the floor
Postby myswys » Mon Jan 26, 2015 1:54 pm
Thrust bearing
Postby leon » Mon Jan 26, 2015 4:10 pm
Clutch master cylinder. Plastic crap!
Postby frozen225 » Mon Jan 26, 2015 4:14 pm
Means you need to do your clutch :)
BMW 135i
BMW X1,2.0D
Postby MrMazda » Mon Jan 26, 2015 4:17 pm
Most probably the master & or slave cylinder is shot. I always replace both. Its getting air into the clutch hydraulic system
Postby leon » Mon Jan 26, 2015 4:17 pm
frozen225 wrote:Means you need to do your clutch :)
If it is the master cylinder you only need to replace that. The little pushrod is plastic and snaps. Hell of a job
