My DreamScience K06 Hybrid Turbo Build
Postby Tren » Mon Oct 26, 2015 1:02 pm
So after quite a wait....finally got the resources available to start and finish this build...
Made arrangements with Wayne from Gobey's Auto Centre to do the build for me.
Basically we had to remove the head, shim the block, swap turbo's and put everything back together again...was a lot of work to do...but we did it in a day, to which I am very very thankful to him for accommodating me in that way :D
This man knows his work, and his workmanship and attention to detail is top notch.
I helped where i could, and where i was needed but 95% of the work he did himself.
The turbo i installed is a hybrid DreamScience turbo built by AET and Forge. it has a standard exhaust wheel on it, but has the k16 compressor wheel from the RS turbo.
It has a forge actuator (blue spring) and forge recirc valve. Really is a top quality hybrid turbo.
I havent had much time to drive the car, but i pushed 3rd gear where i could...im driving on pump fuel at the moment...and all i can say is that this car will murder my stock turbo ST with OB1 on its best day...which was last weeks 13.2 :lol:
Im really happy and excited to see how it performs in the higher gears...just busy monitoring oil and water..but everything seems spot on so far :smt023
Car should make between 360-370hp and 600nm... will be dynoing soon and will post the results :)
Some pics of the build...
Was 30 odd degrees in CT so we made an aircon quickly haha
Virginity Broken LOL
Just sanding the part where the shims are to make sure no part of the shim sticks out higher than the block..
shims all in :smt023
found 5 stripped threads in my head...so the guys from swift thread came out to sort that out for me.
Head back on..
Swapping out my RS 440cc Injectors for the Bosch 550cc
Applying sealant to the tappet cover...
Fluids going in...went with EVERON antifreeze, only heard good things about it.... Oil i used was Pertamina Fastron.
Selecting my new Map, this is a DreamScience Generic file written for the K06 Hybrid with 550cc injectors
Downloading the map...
Map Installed
Model: R8 V12
Type: V-TEC
Re: My DreamScience K06 Hybrid Turbo Build
Postby Jon-T5 » Mon Oct 26, 2015 1:12 pm
Niiiiiiiiiiiiiiiiice benTren.
Keen to see some onboard vids!
Now, I admit that there are two distinguishing features that you can use to tell apart the Audi sedans. One is LEDs. The A4 has roughly seven, while the A8 could guide damaged ships to the mainland.
Postby Tren » Mon Oct 26, 2015 1:14 pm
Jon-T5 wrote:Niiiiiiiiiiiiiiiiice benTren.
Lols why you using vag username here hahaha
Shot bru!, yeah will make some soon :smt023
the acceleration is crazy...and makes my stock turbo seem slow...thats all i can say for now... :lol:
Model: R8 V12
Type: V-TEC
Postby Jon-T5 » Mon Oct 26, 2015 1:20 pm
My bad Otter :lol:
Model: Vito
Type: 115 CDi
Postby Mexican » Mon Oct 26, 2015 1:20 pm
UCBR again
2010 Merc Vito Crewbus 115CDi
2015 Suzuki SX4 AllGrip
EX:Audi S3 8P
Stealth Tuned
Postby Cornel » Mon Oct 26, 2015 1:23 pm
Nice mr congrads on the turbo upgrade
Postby Tren » Mon Oct 26, 2015 1:24 pm
Mexican wrote:UCBR again
You can give me one under the able in BK when you down :lol:
Cornel wrote:Nice mr congrads on the turbo upgrade
Dankie!
Postby convict 66 » Mon Oct 26, 2015 1:43 pm
nice tren
Postby P Dubs - C21 » Mon Oct 26, 2015 1:53 pm
Great stuff Tren! Please change oil more often. LOL.
We can gauge against my RS. Should be easy for you :)
Postby Tren » Mon Oct 26, 2015 2:09 pm
convict 66 wrote:nice tren
Thanks bru!
P Dubs - C21 wrote:Great stuff Tren! Please change oil more often. LOL.
LOL did you get your map loaded ? :lol:
Postby myswys » Mon Oct 26, 2015 2:16 pm
Now go fetch that 12s. Looks awsome
Postby Tren » Mon Oct 26, 2015 2:19 pm
myswys wrote:Now go fetch that 12s. Looks awsome
Dankie Tannie...i plan to fetch it next month hopefully ;)
Model: Premacy
Type: Aircon+ Hooter
Postby DTM » Mon Oct 26, 2015 2:19 pm
Nice work and upgrade there Tren we want vids :D
AUDI B7 2.0T DTM
SOLD
Postby Tren » Mon Oct 26, 2015 2:21 pm
DTM wrote:Nice work and upgrade there Tren we want vids :D
Thanks Bru, will make a few soon :smt023
Postby P Dubs - C21 » Mon Oct 26, 2015 2:52 pm
Thanks bru!
No. LOL. But 220kw car is easy for you mos :P
