Mk6 fiesta 1.6 swr cams
Make: Mitsubishi
Model: Lancer Evo Ralliart
Type: slow
Year: 1996
Re: Mk6 fiesta 1.6 swr cams
Postby general_lee » Sun Jul 24, 2016 10:09 am
Very nice.. Looks like it'll flow as intended..
Sent from my SM-G930F using Tapatalk
Just a stock Jap car
Type: 1.6 Trend
Postby Walnut01 » Wed Jul 27, 2016 1:57 pm
Got my springs:
Will fit them to the car this week hopefully.
Postby Shaunp » Wed Jul 27, 2016 4:21 pm
Nice
Type: 1.6 Trend
Postby Walnut01 » Fri Aug 12, 2016 1:58 pm
So having a slight problem.
My mechanic has put my car back together after i had the head polished and the cams cut to 268 deg. It starts fine but then the crank slips.
We have replaced the crankshaft center bolt with a brand new one from ford, thinking it was this but it is still slipping.
Anybody have any ideas?
Postby Stu » Mon Aug 15, 2016 7:41 am
did u put the 4 diamond washes back in that hold the crank pulley
Type: 1.6 Trend
Postby Walnut01 » Mon Aug 15, 2016 10:31 am
Stu wrote:did u put the 4 diamond washes back in that hold the crank pulley
Thanks Stu
I called my mechanic and told him to check it.
What do those diamond washers do? You don't think that the head work could be affecting the crank position? They get it all setup and then the things goes out of alignment.
Postby Cornel » Mon Aug 15, 2016 10:33 am
Walnut01 wrote:
sexy wrote:did u put the 4 diamond washes back in that hold the crank pulley
Thanks sexy
What do those diamond washers do? You don't think that the head work could be affecting the crank position? They get it all setup and then the sexy things goes out of alignment.
BWHAHAHAHAHAHAHA
Type: 1.6 Trend
Postby Walnut01 » Mon Aug 15, 2016 10:46 am
Cornel wrote:
Thanks sexy
BWHAHAHAHAHAHAHA
HAHAHAHAHAHAHAHAHAHAHAHAHA :shock: :lol:
Why is it converting his name to Sexy!!!!!!!! In edit it shows correct...................
Type: 1.6 Trend
Postby Walnut01 » Sat Aug 20, 2016 11:51 am
So car is back.
It doesnt idle when warm but i recon thats due to the cams and head modifications. It will go for its chip and tune this week. It runs smooth while driving.
Spent the morning fitting the CAI and a new set of front disc pads and brakes, also cleaned up the engine bay and got rid of all the grease marks from mechanics.
Still need to fit my engine mount but i cant get the old one off so i will take it to a shop to remove.
H&R springs installed. The ride quality is excellent, it feels just as comfortable as stock.
Type: 1.6 Trend
Postby Walnut01 » Mon Aug 29, 2016 10:44 am
Car was dropped off at KSD this morning.
Will post results when i get them later on.
Type: 1.6 Trend
Postby Walnut01 » Fri Oct 14, 2016 1:52 pm
I forgot to update this thread.
The car went to KSD where it was chip and tuned.
The car is running a 268 deg cam, full free flow exhaust, Unichip, K&N filter and polished head.
The results were 87kw and 149nm. The car drives really lekker, especially with the H&R springs and lower engine mount. From 1st to 2nd the wheels give a lekker chirp (thats with 205 wide wheels). It also sits in traffic everyday for 2 hours and has no problem.
I took the induction kit off as i dont like the noise it makes, instead i am running a flat panel K&N filter. If anybody wants to buy the old one let me know. I will sell it for cheap - R400? Thats the pipe, filter and silicon ends.
I am now looking at getting my exterior sorted and then the interior steam cleaned, the mechanics really made a mess inside. Then its Powerkote brakes and i want a SWR CAM to really increase the power :D
Type: 1.6 Trend
Postby Walnut01 » Fri Oct 14, 2016 2:14 pm
Return to Fiesta Projects
