My new wheels
Re: My new wheels
Postby Cornel » Wed Aug 02, 2017 9:56 am
Random-Hero wrote:leka man. Nou kan ons rice.... hehe
Should be interesting but I think you'll be in front. Jy het lekker UCBR in die tank, ekt net stickers
Re: My new wheels
Postby Cornel » Tue Aug 08, 2017 8:03 am
So I had the car dyno'd at Kar on Saturday.
My new power in 4th gear:
5th gear:
I'm super happy with the results.
Car pulls strong now. Big ups to Keithan from RK Motion!
Make: 1L Ford
Model: 2L Ford
Type: 3L Ford
Re: My new wheels
Postby V6 Capri » Tue Aug 08, 2017 8:51 am
Very nice power that... and nice smooth graph.
What was the "before" ?
Beste resep in die wereld! 1L Ford, 2L Ford & 3L Ford!!
Image+Image+Image
Re: My new wheels
Postby Cornel » Tue Aug 08, 2017 9:06 am
V6 Capri wrote:Very nice power that... and nice smooth graph.
Thanks mnr
The "before" was done on FR&R's dyno.
Made 104.6wkw and 359nm stock.
Made 122wkw and 420nm after FR&R.
Now 147.4wkw and 490nm at Kar after DP and RK Motion. Car pulls much smoother as well. Much more fun to drive plus all the safety features is in tack.
Re: My new wheels
Postby Boolee » Tue Aug 08, 2017 9:31 am
That torque is crazy. Thing must pull hard!
Re: My new wheels
Postby Cornel » Tue Aug 08, 2017 10:17 am
Boolee wrote:That torque is crazy. Thing must pull hard!
thanks mater. ja gets side ways much quicker
Re: My new wheels
Postby Cornel » Tue Aug 29, 2017 10:07 am
Update Time
So seeing as I make a lot more torque now, I needed new rear tyres sooner.
In Kuruman we pay a premium price for everything. I got a quote for two new Bridgestone Potenza RE050 RFT at R8k without alignment. I the city this would have been R6.5k for alles.
So I had to make a call. Elton did not make it much easier with his 403M wheels that was for sale.
It's awesome to be apart of a lekker tuning family. Kyle (Low Flyer)had a look at the wheels for me. Wife wanted to know everything is all good on them. Everything checked out good.
So I made the payment to Elton on friday, what a nice guy, and my father collected them on saturday.
They original 403M style BMW rims with Toyo tyres.
I need spacers now. But need to sort a few other bits on the car first. Want to do my damper pulley, Shocks with springs and gearbox service before year end.
Also sprayed my plastics. They supposed to be gloss black. But i sort them out in december with proper 2k paint. Can spray is ****! I set the standard very high for myself as this was how my parts normally looked on clients cars. According to me you will never ever get this type of results with can spray and polish. I like deep gloss black parts!
On to the pics.
Excuse the crappy pics. Will take better pics this weekend when it's all cleaned. Also adding some RK motion stickers.
Re: My new wheels
Postby frozen225 » Tue Aug 29, 2017 2:15 pm
Looking good Cornel :smt023
BMW 135i
BMW X1,2.0D
Re: My new wheels
Postby Cornel » Wed Aug 30, 2017 6:16 am
Thanks uncle frozen
Re: My new wheels
Postby Cornel » Mon Sep 04, 2017 6:47 am
Cleaned my car a bit.
Just love how it sits now. Still a few things that I need to sort out on it.
Re: My new wheels
Postby Cornel » Thu Feb 08, 2018 8:23 am
Forgot to update on this forum
Fitted the Spacers. Fronts is 5mm and rear is 12mm.
My before and after pics looks real **** so I'm posted the rear ones only.
Fronts:
Rears:
Right side rear
Before:
After:
Left side rear
Before:
I also fitted the 4 boost housing seals on the boos pipes. I did not take any pics of that.
The came the fun part. Fitting meth to a BMW is **** baie work! Just ask Dewald(Bloubul) as he did most of the work! Thanks buddy you a Legend!
I went for a Universal Cool Boost Stage 2 Progressive kit. We wanted to play around with the nozzles to see what will work the best.
Opped of a CB5 nozzle in the end.
This is where I wanted my bottle and pump to be as i did not want to loose to much boot space.
So we decided to get a Lion and some ply wood (dewald wanted to paint it as he wanted to make it look lekker behind the covers) :lol:
So it ended up looking like this at the end.
Next up was to get the meth line all the way to the engine bay. So we stripped all the panels at the bottom of the car. Removed the front bumper to get to the cooler.
And you'll need something cold to help you focus.
Dewald tapped the meth into the cold side on the cooler
He tapped for boost into the hot side of the cooler.
Then we installed the non-return valve and the fault switch.
Vacuum line. Note its red in most of the pics. On the first run without meth the line popped off, so we took some cable ties as we could not found small enough clamps. Second try the line burst. So we bought a new line(blue one from XXX Centurion). Excuse how dirty the bay is.
[hr]
Next up was all the wires. We needed to check what wires needs to stay at the back and which of them needs to go to the front. Dewald busy with the schematic, **** load of wires!
All tucked away
Sticked down with double sided tape till I can make up my mind where I want to put it.
Also have a on/off switch.
After everything was sorted on the car, we took it for a run without meth to check that everything is fine. After the two fail attempts it was time to open up the meth kit. Testing was done with water only.
Intake temps managed to drop from 40 degrees to 34 degrees in just 2 gears. So i was very happy as this was the main reason I went with a meth kit.
Before that run
After the run
And then Dewald filled her up and gave me some spare meth. Thanks buddy!
We went to the dyno as well. Managed to gain 9wkw and 40nm with the meth turned on on the second run(no time to adapt)
I also did a service on the car. The following was changed:
5.2l Liqui Moly 4100 Oil
Oil Filter
Fuel Filter
Cabin Filter
Air Filter
Wipers.
Keithan did the stage 1 gearbox flash as well.
Now time for Stage 2 or 3 with new update file.
Thanks to all that helped me with the car! Really appreciated it
I have some extra goodies that's arriving today as well. 335i carbon diffuser, double din m4 style kidneys and air scoop vents.
Make: 1L Ford
Model: 2L Ford
Type: 3L Ford
Re: My new wheels
Postby V6 Capri » Thu Feb 08, 2018 9:20 am
Very nice upgrade! Well done!
Image+Image+Image
Re: My new wheels
Postby Cornel » Mon Mar 12, 2018 2:34 pm
Little bit of an update on my car.
Car went to Keithan last week Thursday.
WOW!
Keithan updated my file and gave me stage 2 gearbox file!
Once we started the car, you can hear that it sounded different, don't know how to explain, but it sounded flippen nice. Has a deep sound to it. Sounds lekker when it changes gears as well. Almost as if its a dsg that changes. Down shifts in Sport ahhh i cant stop. Will see if I can fit the gopro some time.
Keithan told me I must forget about consumption on the car, lol.
I filled up in Vryburg, had stop and go's, cruise control 130km/h. Car said 18.5km/l and pump said 19.3km/h. Last night when I pulled into my house, the car said 20.4km/h, so will be interesting to see what i got.
Car pulls strong for a little 2.0l!
I can't explain how happy I am that Keithan tunes my car!! Buddy thanks a lot for all your effort that you've put into my car! I really appreciate it!
Tried to get the colour on a camara
While i did the exhaust they saw my mounts is done. So i replaced them.
Then this happened
Cleaned the rear before some runs in Klerksdorp
Never saw this on another car before! RK Motion FTW!!
Re: My new wheels
Postby Cornel » Mon Mar 12, 2018 2:36 pm
I cruised at 165km/h from Keithan last week thursday evening. This was what my computer said. Keep in mind that my computer said 18.5km/l and when i worked it out it came to 19.3km/l. So overall im very happy!
Re: My new wheels
Postby Cornel » Mon Mar 12, 2018 2:37 pm
Here is two video's of my exhaust
https://www.youtube.com/watch?v=Hz4lPgZPn0k
https://www.youtube.com/watch?v=u_H2cwdxXa0
The white smoke will be because of the meth.
Return to Ford Showroom
