Not a Ford but at least it is the RS
MrMazda
Re: Not a Ford but at least it is the RS
Post by MrMazda » Tue Oct 13, 2015 6:20 pm
W0LF wrote:1000km is more than enough of a run in.
2000km if you really want to be safe.
You do need to do a run in on a rebuilt motor.
Standard motor from the factory not as vital as the motor is already started and tested in the factory AFAIK.
Engines & gearboxes get pre -assembled & together had probably done a good few 100 km on a dyno before assembly. Oil & filters get changed during vehicle assembly, that 's why they no longer require a 1000 km oil change
Diidy
Make: Toyota
Model: Corolla
Type: RSi
Post by Diidy » Tue Oct 13, 2015 7:27 pm
Congrats! Amazing to think that both Ford and Audi where producing 5 cylinder RS models of very different kinds of cars at around the same time.
About the running in period, its only required when forged pistons are installed, 3-5000km's running in at low boost allows enough for the new rings to set before they can be used to their maximum. Most of the other parts would not need nearly as much distance to run in otherwise.
2000 Corolla RSi 20V
2005 Ford Fiesta ST150(Ex)
1999 Corolla RXi 20V(Ex)
1995 Golf III 1.6(Ex)
myswys
Post by myswys » Wed Oct 14, 2015 6:11 am
Diidy wrote:Congrats! Amazing to think that both Ford and Audi where producing 5 cylinder RS models of very different kinds of cars at around the same time.
Thanks, ja the previous owner did install forged pistons. Apparently the previous owner used to work on Cosworth engines many moons ago, he did the transformation of the engine himself, a pure petrolhead with loads of knowledge.
MikeyS
Make: Nissan
Model: GTR
Type: 35
Post by MikeyS » Wed Oct 14, 2015 7:41 am
Wat hes name ?
GAZA5GP
Post by GAZA5GP » Wed Oct 14, 2015 7:44 am
Wat hes name ?
Kan Nie Sy Naam onthou nie.. Maar ek dink dis daai ou wat n kar skoon maak met sy blower!!
8)
PoopandPee
Post by PoopandPee » Wed Oct 14, 2015 7:58 am
Will this car ever boost. Let's wait and see
myswys
Post by myswys » Wed Oct 14, 2015 8:02 am
Wat hes name ?
8)
Bwahahahahahahaha that guy with the blower also know his cars and engines :lol:
myswys
PoopandPee wrote:Will this car ever boost. Let's wait and see
It's not a Ford, I shall have you know :lol:
GAZA5GP
Post by GAZA5GP » Wed Oct 14, 2015 8:12 am
myswys wrote:
Wat hes name ?
8)
:lol: :lol: Ja Nee Ek Kan Dit Glo!
V6 Capri
Post by V6 Capri » Wed Oct 14, 2015 8:18 am
Wat hes name ?
This please?? ^^^
Can only be a handful of people...
1964 Ford Anglia 997cc
1972 Ford Capri 3000GT
1994 Ford Escort Cosworth (replica)
1996 Ford Escort MK6 Zetec Turbo
myswys
Post by myswys » Wed Oct 14, 2015 8:34 am
Wat hes name ?
This please?? ^^^
Hy is van die oosrand, hy ry glo net gewoonlik Porsches? Ek het nie n idee wat sy naam is nie.
PoLonY
Post by PoLonY » Wed Oct 14, 2015 8:57 am
Forged pistons will wear in just as fast as normal pistons, you just have to make sure not to push the car when cold due to the pistons being a lil smaller and needing to expand with heat and having slightly larger piston bore tolerances to account for the expansion. If you don't pay attention to that then yeah, glazing the bore etc is easy to do.
The rings are still similar or exactly the same material to stock rings and if the bores are stock material then the run in procedure will be the same.
1000km is plenty, key is to vary load and rpm all the time rather then baby it at steady throttle inputs for 1000's of km.
Think of how many revs the motor will do in 100km let alone 1000. If the bore is gonna glaze, it's gonna happen the first couple km's down the road.
Pulled apart motors with 150k km on them and the hone marks are still clearly visible, shows how little wear there needs to be to "run in" a motor and get everything to seat and last for many km's.
Key is to make sure ring gaps are good and bores and pistons are correct and in spec, that's the most common reason for bad "run in" imo.
07 Volvo C30 T5 met eish
myswys
Post by myswys » Wed Oct 14, 2015 9:09 am
So hubby took the car to Frans this morning and he will sort it out on Monday he said the engine light is still something small.
EwMPS
Model: CX5 / MPS
Type: 2.2d / 2.3i
Post by EwMPS » Wed Oct 14, 2015 12:30 pm
keep us posted, anxious to see this RS boost Mev Mys!
Was nice meeting you and hubby at Tarlton weekend! My misses is also a petrol head and now wants me to get a GTR lol! She aims high, its a good thing :-)
myswys
Post by myswys » Wed Oct 14, 2015 12:35 pm
EwMPS wrote:keep us posted, anxious to see this RS boost Mev Mys!
Will do
Was lekker om julle ook te ontmoet het, lekker om ń gesig by n forum naam te sit.
Is goed daars min girls wat petrol heads is, begin spaar vir daai GTR en laat sy hom ry :D
Return to “Ford Showroom”
