Exhaust Diameter?
Exhaust Diameter?
Postby Eon » Wed Aug 10, 2011 6:18 pm
I want to fit a powerflow exhaust system to my '09 Bantam 1.3i, purely for an improvement in sound, but I have done some research, and saw that if they fit too thick a pipe, there will be a loss in torque. Thicker pipes sound better, but what is the ideal exhaust pipe diameter for my application? I don't want anything too loud though, but if I step on it I want to hear it, and some overrun pop would also be awesome! Any ideas?
Thanks in advance 8)
Type: 2.0 Si Sedan
Re: Exhaust Diameter?
Postby VinBot » Wed Aug 10, 2011 6:34 pm
I'll measure up my freeflow for you tomorrow. I think the 1.3 and 1.6 Rocams have the same diameter.
Type: 2.0 Si Sedan
Postby VinBot » Thu Aug 11, 2011 1:31 pm
It's a 50mm pipe from front to back. I went for a subtle system. It sounds much better than standard, but does not drone horribly at hi-way speeds. My system consists of a small tube like silencer thing after the manifold, then a medium sized box in front of the rear axle and a larger back box at the rear.
No idea if any of this is relevant to you, but just to answer your initial question again, it's a 50mm pipe :lol:
Postby leon » Thu Aug 11, 2011 1:47 pm
VinBot wrote:It's a 50mm pipe from front to back. I went for a subtle system. It sounds much better than standard, but does not drone horribly at hi-way speeds. My system consists of a small tube like silencer thing after the manifold, then a medium sized box in front of the rear axle and a larger back box at the rear.
I guess for that size engine you could do a 50mm pipe, however I would do a good freeflow box only if sound is your only requirement. Will give some performance and better sound without breaking the bank
Type: bakkie
Postby Waheeb » Wed May 11, 2016 11:47 am
I have a 2010 bantam 1.3 and I had a 50mm Powerflow stainless steel system installed with the biggest middle and rear boxes that they had available to fit. Its quiet when idling and has a nice deep sound on accelleration, but not loud. Below 3500 rpm it feels like its a bit slower to rev up, but once you hit 4000 rpm she growls and starts increasing accelleration dramatically.
I've also installed a K&N CAI and a breather filter on the tappet cover. I have not had her on a dyno so I have no idea what kind of power gains/losses was made.
Make: Chevrolet
Model: Sonic RS
Type: 1.4 Turbo Beasty
Postby Skywalker » Wed May 11, 2016 12:33 pm
I have a 50mm viper system with a set of headers on my Chev 1.4 UTE, and it really works well on the little motor. Power wise, I doubt it made a huge difference but the peak torque comes in earlier and holds longer, making it more enjoyable to drive.
Model: Premacy
Type: Aircon+ Hooter
Postby DTM » Tue Jun 14, 2016 8:27 am
Yes 50mm would be perfect anything above 57mm your wasting your time and money.
AUDI B7 2.0T DTM
SOLD
