Ford ikon/bantam/fiesta radiator fan (not aircon fan infront
Type: MK5
Postby flouwford » Mon Nov 16, 2015 9:05 pm
Now for the next interesting thing.
Finaly as soon as the rain settled i could open up garage and let the ikon run hot till fan comes on. Everything is dry and sound.
BUT. The fan is running the wrong way.
Interestingly, nowhere i can spot any wiring being fiddled with from the fan, to speed switch, to relay box.
everything still looks factory.
Now my only conclusion, the previous fan packed up, and the replaced it from another model.
Where the fans wires plug into the rest of the loom, on that plug the wire coulors swop over.
I can easily cut and swop the wires over at the fan itself. But not sure if there might be something else broken. That wil make the direction chance. My mind tells me its impossible. But i have been wrong before.
Any thoughts?
Model: Ranger
Type: WildTrak
Re: Ford ikon/bantam/fiesta radiator fan (not aircon fan inf
Postby Danger Boy » Tue Nov 17, 2015 10:32 am
DC fans normally have protection built in for when the polarity is changed. So chances are that it will not spin.
Give it a try. I might have a fan from a '98 fezz for you if you blow than one up.
Type: MK5
Postby flouwford » Tue Nov 17, 2015 10:34 am
Danger Boy wrote:DC fans normally have protection built in for when the polarity is changed. So chances are that it will not spin.
Already swopped the wires.
And is spinning the correct way now.
Hou maar daardie spaar fan naby....
Jyt nie nog n ou stel 14" mags daar by jou nie?
Model: Ranger
Type: WildTrak
Postby Danger Boy » Tue Nov 17, 2015 10:45 am
That is interesting. At least it works!
Michael het sy mags verkoop nadat hy die kar gerol het :o
Is Dewald still on the forum? He organized mags quick quick....
