Help Needed
Legin
Help Needed
Post by Legin » Mon Sep 03, 2018 12:55 pm
Hi Guys
I am currently rebuilding a N/A Ford Escort 1999 which was originally a 1.6 ZETEC and was swapped for a 2.0 Mondeo 2.0 ZETEC.
The problem I have is when i start the car the car will start, idle, rev throughout the rev range etc. Problem is when i drive it it stalls like there is a lack of petrol. Funny thing is when it stalls during the drive I would switch it off and on again it will go away till i gear down to low speeds or have come to a stop etc. I have replaced the MAF already also checked for leaks on the intake as well, had the injectors cleaned, a new fuel pump and fuel pressure regulator.
Any help will be appreciated?
thanks
LIFE IN THE FAST LANE
Ex : Ford Focus ST 2007
V6 Capri
Make: 1L Ford
Model: 2L Ford
Type: 3L Ford
Re: Help Needed
Post by V6 Capri » Tue Sep 04, 2018 9:09 am
What management are you using?
1964 Ford Anglia 997cc
1972 Ford Capri 3000GT
1994 Ford Escort Cosworth (replica)
1996 Ford Escort MK6 Zetec Turbo
leon
Make: Focus ST
Model: Karolina Kurkova
Type: 36-32-36
Re: Help Needed
Post by leon » Tue Sep 04, 2018 5:03 pm
check all the earth connections and suspect the pump relay as well
Hawking's radiation does not boil eggs
Legin
Re: Help Needed
Post by Legin » Wed Sep 05, 2018 1:24 pm
V6 Capri wrote:What management are you using?
using my existing ECU in the car.
Legin
Re: Help Needed
Post by Legin » Wed Sep 05, 2018 1:28 pm
leon wrote:check all the earth connections and suspect the pump relay as well
Earth is fine, would the relay then not effect it when holding rev ranges as well?? It doesn't have any issues through the entire rev range only when i start driving it nose dives.
V6 Capri
Make: 1L Ford
Model: 2L Ford
Type: 3L Ford
Re: Help Needed
Post by V6 Capri » Wed Sep 05, 2018 1:36 pm
Don't think the standard management is equiped to upgrade the increase from 1.6 to 2.0.
I know Wayne used a specific Mondeo ECU for his conversion.
See his sal thread here viewtopic.php?f=15&t=76323
and his build thread here viewtopic.php?f=14&t=40748
waynegc
Make: Bakkie
Model: Bakkie
Type: Bakkie
Re: Help Needed
Post by waynegc » Fri Sep 07, 2018 1:48 pm
Been a long time since I was on this forum :D
Also still have the car, couldn't get it over my heart to sell it.
Yeah, when I started I used the normal 1.6 ECU, I then imported a Mondeo's ECU without PATS from EU then with the extra stuff I did a had a unichip fitted.
One day when I'm big, I'll fit a haltech.
V6 Capri wrote:Don't think the standard management is equiped to upgrade the increase from 1.6 to 2.0.
1996 Escort 2.0 with VDL magic
2012 Bakkie
Horsepower is how fast you hit the fence.
Torque is how far you take the fence with you.
Return to “General Ford Tech Talk”
