Paint touch up on my RSi
Type: 1.6 RSi Turbo
Year: 2003
Postby Assassin » Wed Oct 09, 2013 3:25 pm
I bought my Fiesta RSi from a car dealer in Centurion. Hoped he would have gotten some stuff sorted before I took the car, but no luck.
There is a nasty gash here and there and I need to touch it up before it goes into rusting mode with the rainy season coming up.
Can anyone point me in the right direction of someone that could possibly assist without having to repaint the whole car?
Thanx
Re: Paint touch up on my RSi
Postby JuST170 » Wed Oct 09, 2013 3:58 pm
Post some pics of how bad it is, maybe it will buff right out
Magnum Grey ST170 - "Drive the Benchmark"
Type: 1.6 RSi Turbo
Year: 2003
Postby Assassin » Wed Oct 09, 2013 9:38 pm
Its very bad, looking at a 10mm gash right up tot the bare body of about 120mm long. Started rusting a bit even before I bought her, so need to touch it up asap. Will send picture asap.
Type: 1.6 RSi Turbo
Year: 2003
Postby Assassin » Thu Oct 10, 2013 8:23 am
Here is the worst damage on the RSi
Bought her with the damage as I am sure its repairable....
Type: 2.0 Si Sedan
Postby VinBot » Thu Oct 10, 2013 5:35 pm
That bumper section will be easily repairable with some grey filler primer and 2K paint and 2K clear that can even be mixed up for you into an easy to use spray can at most automotive paint shops.
As for the larger gash on the door or wherever, I'd suggest spraying some rust stop onto the area to prevent it from getting worse until you can touch it up properly.
Return to Ford Interior/Exterior and Lighting Modifications
