Ikon Speedo Cluster
Model: Ikon
Type: 1.6 LX
Ikon Speedo Cluster
Postby Blacky » Mon May 22, 2017 1:32 pm
Hi All.
I need some help. I have a 2000 Ikon. I would like to know if there are white dial kits available and where?
Practice until you get it right
& then practice until you
can't get it wrong
Type: 2.0 Si Sedan
Re: Ikon Speedo Cluster
Postby VinBot » Mon May 22, 2017 7:59 pm
Certain XLE Bantams (double headlight shape) from about 2006-2009 (I stand corrected) came with white faced dials and red needles. It still illuminated green, unless you take it apart and hack off the green filter in front of the bulbs.
Model: Ikon
Type: 1.6 LX
Postby Blacky » Tue May 23, 2017 9:24 am
Thank you.
Will check it out.
can't get it wrong
Model: Ikon
Type: 1.6 LX
Postby Blacky » Tue May 23, 2017 9:30 am
I see the digital display and warning lights is different. Would it be a straight swap?
can't get it wrong
Type: 2.0 Si Sedan
Postby VinBot » Tue May 23, 2017 9:52 pm
Blacky wrote:I see the digital display and warning lights is different. Would it be a straight swap?
I honestly can't say as I haven't personally tried to swap the clusters. On the surface the entire cluster looks like the same shape and I would assume the mounting tabs line up, but can't say for sure that the Ikon connector will plug straight in. The digital display will also reflect the odometer reading of the donor vehicle - I am not sure if it can be reprogrammed to suit.
My Ikon was sold long before I was able to get my hands on a XLE cluster...
Model: Ikon
Type: 1.6 LX
Postby Blacky » Wed May 24, 2017 12:38 pm
Great.
Thank you.
can't get it wrong
Return to Ford Interior/Exterior and Lighting Modifications
